titantdi
Has anyone made a biturbo mk4 jetta? if so whats the power difference, and economy difference?
I don't think so.titantdi said:Has anyone made a biturbo mk4 jetta?
You can get a lot of pressure with a single turbo, with only four cylinders and such a low revving engine two turbos isn't very practical. Power would most likely be about the same as if you were to use a single aftermarket turbo, but really it comes down to what you've done to your ECU. Turbos just do what they're told.if so whats the power difference
Turbos aren't rated by what kind of MPG hit you'll take after installing, this is likely due to the fact that it depends largely on how you drive. If you drive the same as you did before the turbo upgrade, mileage should not make a noticeable change.and economy difference?
If you want a bi-turbo setup get yourself a high performace audi with AWD thats built to handle the added power.titantdi said:Has anyone made a biturbo mk4 jetta? if so whats the power difference, and economy difference?
Nopers.titantdi said:i think you see it wrong, i was asking whether it would be really a cost efficient idea to add a second turbo to a stock tdi.
Very good point EDEd's TDI said:Another benefit of a twin-turbo setup that nobody's touched on would be the decrease in stress on the turbos to provide a comparable amount of boost of a larger turbo and more. If you're running 2 vnt15's right in their ideal boost range of 14-18 psi, you're getting much more boost flowing into the engine without peaking the turbo's to the point where you're shortening their lifespan.
Make sure you tell Jose that I manage to absorb some of the stuff we discuss in the shop!!LA@JSPerformance.ca said:Very good point ED
Not trueEd's TDI said:Another benefit of a twin-turbo setup that nobody's touched on would be the decrease in stress on the turbos to provide a comparable amount of boost of a larger turbo. If you're running 2 vnt15's right in their ideal boost range of 14-18 psi, you're getting much more boost flowing into the engine without peaking the turbo's to the point where you're shortening their lifespan.
Wow if this is the case some one better tell the 12V cummins guys...Drivbiwire said:...
If you want a compound turbo set up then you need:
-Cross flow head
-4 valves per cylinder
-CR injection 7-9 holes ideally
-Pieze actuation
-Bosch 17 series EDC control
-Digital flow control of the turbo
-Design specific combustion bowl
-Digitally controlled Tumble flap to regulate the swirl at all rpm ranges of the incoming air charge regardless of flow, pressure, engine rpm
-Flow specific intercooling
-Custom compressor design (x2)
-Custom turbine wheel design (x2)
My advice is it would be cheaper to move to Germany and buy a BMW than it would be to waste your time trying to get an oudated motor to come close to a state of the art engines performance.
Gotta go to 4 1 Oh...
DB
Well if you want to compare apples to watermelons then I have a CF6 that makes 130,000hp...whats your point.dvst8r said:Wow if this is the case some one better tell the 12V cummins guys...
So one out of eleven and yet there are thousands of working examples including ones that make 220whp/L+, which would be a 440whp+ in a tdi...
So I'm gonna have to call BS on those requirments...
-Cross flow head (yup they got this one)
-4 valves per cylinder (nope) Do your cylinders have 480cc of total displacement? So how do you plan on flowing enough volume to drive dual turbo's???
-CR injection 7-9 holes ideally (nope) Does your Cummins rev to 5100 rpm? Didn't think so! Does your Cummins have to insure perfect distribution of that fuel with multiple injections at 5,000 rpm while working with fuel pressures of 1800 bar?
-Pieze actuation (nope) Does your cummins inject 5 injections per 3miliseconds to achieve the rpms required to produce power from a 1.9L engine while remaining in the ball park for emissions reasons?
-Bosch 17 series EDC control (nope) Again design dictates massive processing power to drive multi stage injection, digital control of the engine systems, and prevent the turbo's from outflowing the motor during transitions in flow and compressor rpms which would exceed 280,000 rpms in the compound applications in the smaller turbo.
-Digital flow control of the turbo (nope) Does your turbo spin at 280,000-300,000 rpms, didn't think so!
-Design specific combustion bowl (specific too compounds, nope as well) The 1.9TDI would require lowered compression to accomodate higher levels of cylinder pressure during combustion. Also the engine would require richer combustion. This would require radical changes in bowl design to achieve fuel air ratios approaching 14.7:1 (vs 33:1 in current TDI engines). The bowl works with the multi hole nozzles to achieve a high level of fuel dispersion and distribution within the bowl to insure optimum combustion characteristics.
-Digitally controlled Tumble flap to regulate the swirl at all rpm ranges of the incoming air charge regardless of flow, pressure, engine rpm (still nope) given the wide rpm range flow characteristics change from one extreme to another. In order to accomodate the strict requirements of bowl swirl and velocity accross an rpm range of nearly 4,000 rpm you MUST vary the incoming air charge to maintain a stable bowl flow pattern to insure dispersion of fuel and prevent melting of the pistons.
-Flow specific intercooling (i know of at least two setups that have no intercooling at all) give the operating temperatures of the TDI intercooling is mandatory to prevent the TIT's from vaporizing the single crystal alloy of the turbine wheel (KP series). Already the temps of the turbines have to endure 1040C without fatigue or failure. factor in richcer combustion and the temps rise to levels that will require extremely efficient intercooling to lower the combustion temps entering the turbo.
-Custom compressor design (x2) (one stock turbo, one stock to another vehical)News flash it does not exist for the TDI in this flow range (yet).
-Custom turbine wheel design (x2) (same as above) What kind of turbine are you thinking that can produce 1bar of boost at low power and flow from a 1.9L engine below 2000 rpms?
You have never seen a Cummins revv to 5000rpm? You are really missing out. That is like your little TDI revving to nearly 9,000rpm!Drivbiwire said:-CR injection 7-9 holes ideally (nope) Does your Cummins rev to 5100 rpm? Didn't think so! Does your Cummins have to insure perfect distribution of that fuel with multiple injections at 5,000 rpm while working with fuel pressures of 1800 bar?
Does your turbo flow 3000cfm at 75+psi of boost, didn't think so!-Digital flow control of the turbo (nope) Does your turbo spin at 280,000-300,000 rpms, didn't think so!
The OP was asking about power and fuel economy not about building a Frankenstien car that can pull a sled and rev to 9000 rpm.titantdi said:Has anyone made a biturbo mk4 jetta? if so whats the power difference, and economy difference?
