Hi,
I am actually working on my Jeep Liberty CRD but figured that you guys may be able to help. I am hoping to be able to tap into the ECU's internal barometer that it uses for adjusting boost and fueling at altitude using Torque Pro. I have been playing with my tune and have had some strange boost readings that dont correspond to what the boost limiter and boost map suggest I should be at, but if I zero out the boost limiter, the boost is what it should be according to the boost map.
TIA
TIA
