G Got diesel Veteran Member Joined Oct 29, 2001 Location Apollo Beach FL TDI None at this time. Jun 1, 2005 #1 I have a Question on the CCV Mod on a 05 Passat TDI,Will this cause any damage to the motor or make it lock up or any thing?
Fahrfuwerfuelen Veteran Member Joined Dec 7, 2004 Location Puget Sound TDI Jetta, 2005 (A4), Platinum Gray Jun 1, 2005 #2 Not unless you install it in some weird way or use some strange method to filter out the oil vapors. If anyhting, the CCV mod will slow down the clogging of the intake manifold. What type of mod did you have in mind?
G Got diesel Veteran Member Joined Oct 29, 2001 Location Apollo Beach FL TDI None at this time. Jun 1, 2005 #3 A hose to the back of the car...
Fahrfuwerfuelen Veteran Member Joined Dec 7, 2004 Location Puget Sound TDI Jetta, 2005 (A4), Platinum Gray Jun 1, 2005 #4 So, what's generally called an elephant hose? This will drip oil onto the road and maybe your car. Why not a ProVent or Old Navy mod?
compu_85 Gadget Guy Joined Sep 29, 2003 Location La Conner, WA TDI ... None :S Jun 1, 2005 #5 FYI, CCV vaoprs are STINKY
jddaigle Veteran Member Joined Aug 30, 2004 Location Denver, Colorado, USA TDI No TDI Anymore Jun 1, 2005 #6 Check in the B5 Passat forums, the ProVent has been fitted to B5 Passats.
