SomeJ
225/55R17What size are your "over sized tires"? Just trying to get an idea of the range I should be looking at without having to enlarge the wheel well.
They look really good and so long as i didnt hit any big bumps or really work out the suspension while turning i never knew they were larger except a slight rub on the outside of the wheel well every now and then (i had to bend/roll the body sheet metal back into place a few times on both front fenders but nothing major). However now the front is starting to sag more than it use to and they will rub inside the wheel well slightly if i hit a big enough bump without turning the wheels. I am kind of afraid to try and pull the fully loaded camper without the new springs at this point as it really makes the back end sag.
Cheers!
J
