My wife's New Beetle 2000 TDI has had the airbag warning light for few weeks. I went to a local garage called Fine Tuning Performance in Seattle, WA, they connected the Ross Tech software scanner and found code 01218 (Passenger-Side Side Air Bag Resistance Too High Or Too Low, Short To Voltage Or Ground) associated with the airbag warning light. After I read the majority of the posts here regarding this issue I did the following:
1. Removed the Passenger seat to get access to the yellow side airbag connector.
2. Disconnected the connector from the seat, Inspected wires, routing, pins and crimps as well. Sprayed with electrical cleaning spray several times (used the nozzle so solution gets well inside the socket and pin side). Note: the sockets are on the car side and pins are on the seat side.
3. I removed each socket from its "seat" and inspected the crimp (be sure to remember the position just in case when you take it out, I think they were 4 "seats" for the 3 wires/pins). I did not use any special pin (socket) removal tools, just a pair of tweezers to push the little locking plate of each socket and then lightly pull on the wire, the socket comes out with an ease.
4. I use a simple sewing needle to check how snug the pin would go into the socket and realize that isn't very tight (that possibly could be sufficient to trigger high resistance at some point - may be when seat is moved hundreds of times causing the airbag control module to register the fault, so I decided to carefully bend the tiny contact plates located on the inside of the sockets (Note: be sure, if you do this to not push to hard, otherwise you could damage the socket). Repeated the fit. Apply this to all 3 sockets. I decided to leave the original connector for now, if the fault reappears in the future I may consider replacing it (I do not think splicing will be a great idea for connector replacement, in case some day you decide to remove the seat and then you are going to need to cut the splices).
5. Sprayed some more electro clean and reconnected connector to seat.
6. Installed back Passenger-Side seat.
7. Fine Tuning Performance cleared the fault, and 2nd day now no reoccurrence of the airbag warning light.
