Been following the forum for quite some time and now I find myself in need of some help.
2003 Jetta TDI Wagon - 346,000km (217,000mi) on the odometer. Original owner. Only mod is Malone stage 1 tune with dynamic egr and high idle. I am experiencing very smokey (like fog a neighborhood out) cold starts and extended rough idle (which eventually smooths out). The rough idle is stumbly and miss like for say 30 seconds (used to smooth out way sooner).
Car always starts and will sometimes start stall but on second fire up always continues to run. No codes. I have kept up with regular maintenance timing belts, changing oil and filter, fuel filters, air filters etc... religiously. I have recently had it at a shop and all injection values and timing are within spec and good. It has also recently had new coolant sensor and MAF sensor and thermostatic T fitting. Glow plugs have been changed a couple times but not recently - no codes so assume they are functioning.
The car never used to smoke like it does now and its rank. I do have a frost heater and when it is plugged in car starts fine as in not idle rough but still smokes.
Could this be related to worn injectors? Clogging Cat (car is subject to short trips)? Is the high idle or more fuel from the tune contributing to the smoke? Car will use about 1 litre of oil between oil changes (every 8000km/5000mi). Other than that seems to run fine especially when warm.
Thoughts??? I love the car just not this smoke I am being subjected to. I am a multiple diesel vehicle owner and understand they smoke but l have had this car since new and I know it was never like it is now. Valve guides? Turbo or Turbo seals? Compression related (have not checked yet)? Failing injection pump or fuel pick up in the tank? I am lost.
TIA for your help.
TIA for your help.
