Hello, i just threw in the towel on trying to find cold start problem. If it is less than 50° and the car sits for the night it has hard start. Sometimes when it sits for only a few hours. I crank it for five minutes until it spudders and then starts. Sometimes it starts to idle but does not accelerate for 5-10 secs. I brought it to dealer and had glow pug recall done. That did not fix problem and they could not help me any further. so i changed lift pump because flow rate was low. Gave me alittle more fuel but didnt fix. So far changed battery, thermatee, fuel filter, and i am getting 13 psi for fuel pressure. After changing lift pump, i hear a swooshing air like sound on the first 1-2 turns then i just hear pump. Fuel gauge also does not pin to full like it once did. I brought to mechanic and he said voltage to glow pug was low and changed relay. Seemed to work for a couple of days then i had same problem. I then brought to him and voltage was fine(it was warm out) it is cold now and he still cant seem to find problem. Any ideas???
