Vanagon tank, about 99% finished
*EDIT: In the summer of 2014, I replaced this tank with an eBay purchase. The rehabbed tank did leak just enough to keep the bottom "damp." But, considering I go into Canada and back into the USA, I was afraid the Border Agents might look under and see the patch on the tank which might end with a search. So, it was time to replace it.
This photo is of the sump with center baffle section in place. It has at least three coats of Red-Kote on it. Also, the grey stuff is JB Weld. I coated it with Red-Kote before installing the sump! According to the manufacturer, Red-Kote and JB Weld are compatible. Notice the outer perimeter of the sump.....bare metal! That will be coated with JB Weld prior to sitting it on the supports (you will see those in the following photos).
This photo shows the templates I made to use to fabricate the aluminum supports that hold the sump in place.
This photo shows the supports laying on the outside of the tank around the hole.
This photo shows the supports inside the tank around the perimeter of the hole. I coated them with Red-Kote, clamped them in place, drilled holes for 1/8 inch pop rivets 1/4 inch long (Made in USA, BTW). Notice the fuel line intake, well that sucker was not easy to snap back on as I sit the sump in place. You can see the hole it goes into on the sump in the first photo above. I left the return line just laying inside! It is stiff and will stay where it is and not be problematic!
This is a closer look at the supports with a mirror showing the back side at the baffle divide.
This photo shows the sump in place. I used JB weld to go around the perimeter before sitting it on. Of course, I pre-drilled numerous holes for stainless screws to hold it on. Also, to the right, notice the JB Weld on the other sump (where the fuel level operates). Those spots had tiny holes. I used the dremil to knock loose the surface. Also, inside, I brushed on several coats of Red-Kote!
And, presto! The tank sitting on the work table. It really looks much cleaner than it appears.
Little secret: I use regular JB Weld and JB Weld Kwik mixed about 75% / 25% respectively and it will set-up quicker than than the regular but slower than the quick and is easy to work with. Also, it is "tested" compatible with the Red-Kote and diesel fuel!
It is my plan to coat the outside of the Tank with something. I'll post the results once I come to a consensus on what to do.
Well, to get 'er done, as best I can tell, I have about 10 hours of work (and a few beers), about $30.00 for the Red-Kote, about $12.00 of JB Weld (all old stuff I had on hand), and no idea how much electricity I used in the electrolysis process.
Of course, there was use of the vacuum, a few paper towels, use of the drill, the jig-saw, some acetone for clean-up, etc.
I would not sell it for $350.00.
...... and, I would not do another for $350.00!
