"Tastes great!" "Less filling!"BoiseTDI said:So which isbetter between the 96-97 passat and the 02-03 jetta?
frugality said:"Tastes great!" "Less filling!"
Depends on your needs. The B4V (96/97 passat) is bigger and has a huge amount of rear seat legroom, but it's an older model and will likely have some rust and other issues, like a saggy driver's seat. The Jetta Wagon will likely be less rusty, and they have newer/nicer conveniences, side curtain airbags, etc. The A4's seats seem to hold up better, but the A4's also have the peeling soft-touch painted interior bits.
Edit after seeing Rxfire's same-time post: The Passats were prone to instrument cluster problems and window regulator problems.
Now let's be fair though. To change the rear shocks on a B4V, you just about have to remove the dashboard...Lug_Nut said:easier strut change-out...
Lug_Nut said:If you'll be wrenching on your own, the engine bay on the B4 is plenty large enough for fat fistfulls of tools, no pendulum motor mount, easier strut change-out, no VNT to stick, simpler wastegate control, simpler EGR system (no feedback loop).
Those tools hurled at the garage wall have to be thrown a bit further to clear the B4 fenders.
see my sig, I pick both... from a maintenance standpoint (parts and other's knowledge) the 03 is better; as Lug Nut said, the passat has more room to work. The Passat is monstrous; my wife uses it as a farm truckBoiseTDI said:So which isbetter between the 96-97 passat and the 02-03 jetta?
Skellys, did you see this ad?:skellysTDI said:Sounds like I got a bad deal.....I guess I have got to askmyself " do I feel lucky"
"absence makes the heart grow fonder" isn't working. There are too many others closer that would be considered, that is: if they were being considered.VWWV said:So...have your PM'd Bismillah (above), yet?
Mine hasn't either since I just replaced the alternator at 71K in August. I'm looking to see if it can make it to November without a hitch...Lug_Nut said:"......(snip).. but the B5.5V hasn't cost me anything in unexpected expenses the past few weeks so I'm not as annoyed with it as I was.
In a word, yep.BoiseTDI said:Those that have searched awhile, is something with this mileage hard to come buy?
quantum_tdi said:In a word, yep.
...Furthermore, the low mileage ones are not necessarily the best. You can see all manner of threads about low mile city-only cars that are hammered vs. highway cruisers that didn't shift or brake for 100 miles at a crack.
