Old May 3rd, 2019, 09:09   #1
ejallison1
Default Using A4 Fuel Filter Set Up on a A3
Any drawback or unknown ramifications if I were to use both the filter and return check valve that goes on top of the filter along with the associated clip of an A4 on a A3? This project 96 Passat had a small inline filter installed and want to go back to something more original. The check valve itself was north of $50 for the A3 setup and filters for the A4 seem more reasonably priced. I wouldn't think it would pose a problem but wanted to verify prior to switching over.
ejallison1 is offline   Reply With Quote
Old May 3rd, 2019, 09:41   #2
Steve Addy
TDI(s): 97 Mk3
I can't think of any reason why that wouldn't be ok.
As a side note some of us have gotten rid of the thermo T check valve and opted for the earlier Mk2 filter that just has the in / out and filter vent. The more connections at the filter the more likely you'll get air leaks.
Having said that when I exhaust my supply of older Mk2 filters I might go back to the Mk3 setup, but it'll be a while yet before that actually happens.
Steve
the magic triangle spins in the peanut and then apex seals come out
Old May 3rd, 2019, 19:00   #3
Mongler98
a filter is a filter, if you can make it work, its fine.
I prefer the Ditzel mod... or however its spelled. CRAZY cheep
Old October 22nd, 2019, 10:29   #4
clyde
What is the "Ditzel mod"? (Searched, found mention but no description…)
clyde is offline   Reply With Quote
Old October 22nd, 2019, 21:01   #5
Mongler98
thats because i cant spell or remember half of these crazy names any more
but a quick google search and this is what im talking about, around here it has a name of Dietzel mod or something.
http://www.peachparts.com/shopforum/...ter-cat-2.html
Old October 22nd, 2019, 21:04   #6
Mongler98
Ah, found my bookmark
The Dietzl Mod
Old October 25th, 2019, 15:14   #7
Steve Addy
TDI(s): 97 Mk3
I remember that mod, always seemed like another solution in search of a problem. AKA spending more money than you need to and making it more complex than you need to.
Steve
Old October 25th, 2019, 18:26   #8
Mongler98
but.. its not, its cheep AF, much cheaper than Nictane and filters are available at like Walmart! i dont know if it is or not but there crazy cheap and available everywhere. Not to mention that it fixes the one issue of air bubbles via that heater T.
its technically making it less complicated.
Old October 25th, 2019, 18:33   #9
ToddA1
Fuel Economy: Dismal
I use the early A2 diesel filters, that get rid of the thermo T. They’re not 2 micron, but I haven’t had a fuel contamination issue.
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is offline   Reply With Quote
Old October 26th, 2019, 11:45   #10
Steve Addy
TDI(s): 97 Mk3
That's really warped logic if you're coming up with 'less complicated' for all that. If you want to do it and want to spend money you don't have to just say so, but don't try and twist it into something that it's not.
The least expensive option is the easiest, and if the thermo T is really a thorn in your side use the older (and very cheap) Mk2 filters with only the bleeder screw on them. These also have water drain on them too. Did I mention they're cheap?
How many of these filters does a person go through anyway?
-Todd
Same thing I'm using right now on the B3V Todd.
As for cheap, Rock Auto was selling the Bosch OE filter for Mk3 / B4 TDI about a year ago on clearance for around $9 each. I stocked up on them, think I bought the last four they had after pointing it out to others via PM.
I still have at least two Mk2 non-T filters to go through also, and those were acquired somewhere for very little.
I recognize these aren't 2 micron but I doubt that in the dead of a mid-west winter I'd be able to pull through a 2 micron filter anyway, at least not without causing the IP some distress.
Again, if you want to do it that's great, but it is indeed a solution in search of a problem.
Steve
Old October 26th, 2019, 20:31   #11
Mongler98
Steve
at least 1 for every 2 oil filters, so usually one every year
Old October 28th, 2019, 23:05   #12
Steve Addy
TDI(s): 97 Mk3
Seems excessive, but that's your choice.
Steve
Old October 29th, 2019, 13:59   #13
garciapiano
The VW-mandated 20k-mile interval seems far too often in my opinion. If anything the filters become more effective as they fill up with debris. There are numerous reports of people basically never changing them and the car continues to run fine.
My understanding is that diesel fuel is filtered pretty well before it goes into the car. I am running my filters for 40,000 miles and have had zero issues, and could probably go for even longer.
Yeah I understand that the filter is cheap enough that it doesn’t make a bunch of sense to extend the interval, but my feeling on that is that the fuel system should be opened to contaminants as seldom as possible. If anything, the irony is that changing the filter increases the risk of dirt getting into the fuel system.
garciapiano is offline   Reply With Quote
A3, B4, A4 injector set ToddA1 Private TDI Items for Sale/Wanted 4 February 2nd, 2018 13:00
FS: NIB Complete Injector Set for A3,B4,A4 otm646 Private TDI Items for Sale/Wanted 9 June 19th, 2015 05:21
2 Micron Fuel Filter Set-up for A4 brian_e Private TDI Items for Sale/Wanted 5 June 29th, 2014 12:40
Bosch Glow Plugs A3, B4, A4 ALH $47 / set VailPowder Vendor & GroupBuy items for sale 0 January 31st, 2009 19:47
Ok to use A4 Fuel Filter on an A3? gaddman VW MKIII-A3/B4 TDIs 2 January 18th, 2009 21:50
Page generated in 0.16883 seconds with 12 queries
[Output: 112.99 Kb. compressed to 95.10 Kb. by saving 17.89 Kb. (15.84%)]
