2015 Jetta VCDS lacks ROD file
autdi
Alabama
2000 NB, 2003 NB, 2006 Touareg, 2015 Jetta, 2013 Beetle, 2013 Touareg
Trying to figure out how to connect to a 2015 Jetta. It seems that the EV name has a B on the end of it that doesn't match any of the supplied .rod files. It worked with the 2014 Beetle, just not the 2015 Jetta.
Pulled the following, I know incomplete scan, but all the rest of the modules came up ok, just not the engine address. Using an older HEX+CAN on the latest software, and it re-flashed the dongle when I used it the first time.
Friday,13,July,2018,17:11:47:30462
VCDS
-- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS
Version: 18.2.1.5 (x64)
Data version: 20180518 DS287.2
www.Ross-Tech.com
VIN: 3VW3A7AJ8FM****** License Plate:
Mileage: 94140km-58495mi Repair Order:
Address 01: Engine
Control Module Part Number: 04L 997 016 B
Component and/or Version: R4 2.0l TDI H20 9468
Software Coding: 01190012042410085000
Work Shop Code:
WSC
03340
VCID: 3261099865599FD4E2-8066
Advanced Identification/FAZIT
Identification: RB8-658
Revision: 8AH20---
Date: 27.10.14
Manufacturer number: 1415
Test stand number: 0785
Flash Status
Programming Attempts(application): 2/2/2
Successful Attempts(application): 2/2/2
Flash Date: 18.06.27
Misc.
Hardware number: 04L 907 309 K
Workshop System Name: J623
ASAM
Dataset: EV_ECM20TDI01104L997016B
ASAM
Dataset Revision: 004002
Car Info
Chassis Number: 3VW3A7AJ8FM******
Engine code: CVCA
VCDS
Info:
Labels: None
Readiness: No script available
ROD: ERROR - EV_ECM20TDI01104L997016B 004002 (VW36)
Address 01: Engine (J623-CVCA) Labels: None
Part No SW: 04L 997 016 B HW: 04L 907 309 K
Component: R4 2.0l TDI H20 9468
Revision: 8AH20---
Shop #:
WSC
03340 444 00000
ASAM
Dataset: EV_ECM20TDI01104L997016B 004002
ROD: N/A
No
ASAM
data for: "EV_ECM20TDI01104L997016B" (VW36)
No fault code found.
Readiness: 0 0 0 0 0
penclnck
Knoxville, TN
I think that has been fixed in the current beta version, but only the current generation HEX devices (HEX-NET and HEX-V2) can use the current beta. In the near future a new standard release of VCDS will come out that will work with the HEX+CAN and that should resolve the issue.
Regards.
Tech20
Texas
2015 Jetta SE 6M
Ross-Tech fixed mine
After phase 2, I could nolonger view 01 Engine. I sent an autoscan to Ross-Tech, and they told me to download the latest version of VCDS. <I assumed that it would update if I told it to check for updates, I was running something like 18.2.0.2, and reinstalling from website was 18.2.0.5 if I recall correctly. It still did not have the rod file needed. Dana replied, and using my earliest known scan to them, from 2017, they were able to send me a functioning ROD file and told me where to save it. She said that it wouldn't be available until the next release for most people. Perhaps you could try your luck with them, or PM me if you would like me to forward my email from them with their attachments.
