KAMIKAZEKMZ
Hy I am wondering if there is some benefit in to chenging de stock intlet valves wich are 29.2 mm with GTI ones wich are 33.8 ?
Second thinking was to modify the exhaust valves from 25.5 mm to 29.2
After that chenging the spring valves with harder ones.
I did research and i didn't find a modified camshaft for this engine only for 1.9'
And I want to increase diameter in to the intake holes of the head right were intake manifold bolts,and changing the diameter of the manifold too with the gasket and the rest remains stock.
Second diameter to increase would be the exhaust.
