Old April 28th, 2015, 22:39   #1
06Nomad
TDI(s): 2006 Jetta
Default 2006 Jetta TDi No Start
I just lost my 5spd tranny and had an opportunity to put in a 6spd. The car was running before the old tranny was dropped, now the problem is, everything is back together....crank, but no start.
Many things have been tried, and thought of, like, the CPS as it was throwing up a fault code, fuses are all ok, and doesn't appear to be a fuel delivery problem as starting fluid sprayed into intake...not even a bite.
Any ideas on this one would be appreciated.
06Nomad is offline   Reply With Quote
Old April 29th, 2015, 01:17   #2
Ol'Rattler
Ol'Rattler's Avatar
Do not use starting fluid on a Diesel, you can cause severe damage. What you need to do is find the problem.
Did you change the rear main seal? If you did and did not have the special tool to align the tone ring for the crank position sensor, you will get a crank but no start condition.
A faulty cam position sensor will still allow the car to start, but will require longer crank times.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old April 29th, 2015, 02:28   #3
wrenchman30
Fuel Economy: 43 best befor egr much better now
well starting fluid can be used if you disable the glow plugs and or intake heater, but if you have tried that and it wont run you have a compression problem, check to see if the exhaust is plugged up and or a intake pipe is pinched
wrenchman30 is offline   Reply With Quote
Old April 29th, 2015, 07:10   #4
06Nomad
TDI(s): 2006 Jetta
Thanks for the info...will check and update later
Old April 29th, 2015, 07:35   #5
whitedog
This.
Old April 29th, 2015, 12:36   #6
Ol'Rattler
Ol'Rattler's Avatar
No wrong. If a Diesel will not start, you need to figure out why. All starting fluid will do is complicate the problem by causing potential severe damage.
Can't remember if I said it before, but:
Do Not Use Starting Fluid On A Diesel!!!
Unless you are into huffing Either, starting fluid has no business being used on even a gas engine, let alone a Diesel. If an engine will not start, you need to figure out why.......
IDK how changing the transmission would result in a compression problem.
Could you expand some on what led up to your no start condition?
2006 Jetta TDI
Draw-Tite hitch
Dash Tray
Euro Cupholder
Euro Light Switch
2nd grocery hook
Old April 29th, 2015, 13:22   #7
Ol'Rattler
Ol'Rattler's Avatar
Answer the red.............
2006 Jetta TDI
Draw-Tite hitch
Dash Tray
Euro Cupholder
Euro Light Switch
2nd grocery hook
2006 Jetta TDI hard to start after sitting TDIJETTA2006 TDI 101 5 December 15th, 2015 01:37
2006 Jetta 1.9 Tdi Won't Start tailon TDI 101 3 November 22nd, 2012 07:46
help...random hard start 2006 jetta tdi cptdi VW MKV-A5 Golf/Jettas 3 March 16th, 2011 07:31
2006 Jetta TDI won't start Jetta Jen VW MKV-A5 Golf/Jettas 3 September 30th, 2010 03:36
2006 Jetta TDI 5M Cold Start Video velociT Jetta/Bora/Vento TDI Picture Gallery 7 February 14th, 2009 20:58
Page generated in 0.15148 seconds with 11 queries
[Output: 82.23 Kb. compressed to 71.41 Kb. by saving 10.81 Kb. (13.15%)]
