Fix_Until_Broke
Ok - I'll try and hit the high spots here....
Engine going together
A walk around the engine more/less together
I wanted to get a very good TDC reference for once and the SBC flywheel does not have a TDC mark on it and there is quite a bit of clearance between the TDC ridge on the transmisison and the OD of the flywheel. So I drilled/tapped the case to install a pointer (1/4-20)
View from the inside
I heated the tip up and quenched it to give it a little harness. I dialed the engine to TDC verified with a dial indicator on the #1 piston with the cylinder head off. Then I put a dimple on the flywheel with the bolt.
