copakabata
- Joined
- Mar 27, 2012
- Location
- Benton, PA
- TDI
- 2002 Jetta 01M, 1999.5 Jetta 5 spd, 2000 VW Golf 4dr 5 spd
I also posted this in the TDI 101 forum, but surpisingly did not receive any responses. Hopefully I get some here.
Here is the link for the more detailed version of my situation:
http://forums.tdiclub.com/showthread.php?t=363578
Quick version of my situation:
Day 1
'99.5 ALH, will not start. Found black 109 relay, verified it was bad, and changed it out with a good gray 109 relay. Cranked, no fire. Bled injectors / fuel lines, after 30 minutes of cranking, bleeding, letting starter cool, I got engine to "cough" twice, and white smoke from the tail pipe.
Day 2
Tried to bleed fuel lines to tank with small electric pump. Pumped for a while, eventually got fuel, but was getting air bubbles throughout. Once I removed suction, fuel sucked back into tank. Tried bleeding return line after IP, got nothing (no air, no fuel). Tried starting car one time, no smoke, no fire.
Day 3
Thought perhaps fuel lines were cracked. So, I installed clear vinyl tubing and funnel to in line of IP, and filled with diesel fuel. Tried bleeding / starting process again. Results were better, every time I tried to start after bleeding, engine "coughed", like it wanted to start, but wouldn't.
Help! Ideas? Please?
TIA
Day 1
Day 2
Day 3
TIA
