-this is false, it depends on what system you purchased. If memory serves me correct you purchased an Eric jaeger module. If you purchase the westfalia module, the module will in fact take NAR settings. Several people have and can confirm this.
-also false this was in your case most likely due to the module that you purchased. If you buy the actual oe module made by westfalia, there are no diodes needed. It is completely 100% plug and play system. No converter is needed with the oe westfalia trailer module.
That is not the case with the westfalia module as I used and so did GJAS18. There are no additional diodes needed and it DOES work for the NAR Jetta with no additional diodes etc.
You only have to make sure that
1.you purchase the genuine westfalia tow module. Both GJAS18 and myself purchased ours from pfjones.
2.you make sure that you specify to pfjones that you are purchasing the LHD, not RHD version of the module to ensure compatability with the NAR region cars.
3. If your trailer has led lights or if you're planning on upgrading your trailer to led, you have to make sure you're selecting the correct westfalia module that supports it. They have 2, one that supports led and the other thay does not. Both will work with the trailer, but if you purchase the module that doesn't support led you will constantly have the bulb out indicator lamp on the dash on.
Make sure you purchase the 13 pin version. It is a more robust system and supports more options, such as a dedicated 12v to charge a second battery etc. It also allows for an easier install of electric brakes if u go that route.
As I mentioned before, I would purchase it from PFJONES. Both myself and gjas18 did so and had no problems with our systems. Others, including red , purchased modules elsewhere and had issues with theirs.
I can attest wholeheartedly if you go the route that I suggested, it is a complete 100 percent plug n play system. It is an easy install, especially for the golf as the bcm is the same as ROW. On the passat and in my case the jetta, the bcm is a bit more of a headache as the install instructions are for row vehicles and the NAR Jetta and passat have their own hybrid bcm with pin outs that do not match any other car. So I in essence was a guinea pig when I did my install, as I was the first documented NAR install for the mk6 jetta. But I did a pretty thorough writeup that I posted the link to, that will make that same install a lot easier for whoever chooses to install it in theirs.
This is the kit that I purchased:
http://www.pfjones.co.uk/vag-tow-bar-13-pin-dedicated-wiring-kit-321600300153.html
I installed it in my 2014 jetta tdi. When you order make sure you're ordering the westfalia kit, your option for led or no led (I didn't opt for led), and that you contact them and let them know to remove rhe vat from the price (ordering outside of the uk requires no vat charge) and that you're purchasing it for a LHD version car.
Again, do as you please but like I said I can confirm for a fact both gjas and myself went this route and had zero problems. You're in a far better position to buy now than gjas and myself were in as 1. We were both guinea pigs for our perspective cars
2. The gbp to usd was pretty crappy then. It's a lot better now so it comes out cheaper
3. The price is a lot cheaper overall. If I'm not mistaken I paid almost 300 before the usd to gbp conversion and minus the vat, and also they didn't include shipping then. So it may have been over 300 bucks. Can't remmeber now
Sent from my SM-N910V using Tapatalk
