sammie
jetta has almost no power going up hills. seams the harder i push on the peddle the slower it goes. used to run lake a bear any thing i can do?
There is a lot of information on this web site you could spend hours reading. Most common causes dirty fuel filter, air intake restriction, faulty mass airflow sensor, turbo boost leak at hose connections etc.sammie said:jetta has almost no power going up hills. seams the harder i push on the peddle the slower it goes. used to run lake a bear any thing i can do?
