BolaB4V
- Joined
- Dec 30, 2007
- Location
- Northern NY
- TDI
- 1996 passat tdi wagon, 97 F-150 XLT 4x4, 99.5 Mk4 Jetta VR6/5M
Changed the inner and outer tie rod on the drivers side yesterday. Now Im feeling the steering wheel move by itself back and forth a little while going down the road. I know it could use an alignment now, but it didnt do this before I changed the tie rod. I counted the threads to the outer tie rod nut from the old tie rod and set accordingly. I assume the setting I did has the caster out too much? The car drives straight otherwise. the steering wheel is about 5 degrees to the right of top center now as opposed to 5 degrees to the left as before. Before I changed the t-rod felt a slight shimmy and the tire did have some movement when shakeing at 9 and 3 oclock, but that went away with rod installed, but now it traverses/pulses back and forth a little,,very little, but not the result Id hoped for after the t/rod replacement. As best I can tell the rack boots are fitted properly,,they were a real hassle to get on to say the least.
