First, a quick model lesson. A B7 Passat is what is available throughout the world, except for North America and China. We get what is referred to as the NMS Passat. On first glance they look the same, but are in fact quite different cars.
Lesson over
For the NMS Passat, there are issues with AdBlue tank heaters, clogged heater cores, and of course failing high pressure fuel pumps (HPFP) that takes out the entire fuel system on failure. If your state mandates a small percentage (at least 2%) of BioDiesel mixed with diesel at the pump, the odds of a HPFP failure goes down (but not eliminated). I should also mention that mis-fuelling the car with gasoline is a probable cause of failure for some of them.
Now, don't think that the odds are high for these issues happening. Some people are well over 100,000 miles with no issues. However, you asked.
The fact that this car has reached almost 90,000 miles is good, as long as scheduled service has been documented. For example, the DSG requires service every 40,000 miles, so it should have been done twice by now. Brake fluid should have been flushed, and of course the normal items (oil and filter changes).
Just as an FYI, in case your research overlooked it. The 2015 Passat, while still sporting the same body, has a completely different engine than the 2012-14 versions. There's no guarantee the HPFP issue is resolved, but the failure rate has dropped tremendously over the past few years (the problem goes back to 2009 with the first common rail engines in the Jetta and Golf). There's only been a tiny handful of 2015 pump failures.
If the car has been well maintained, I personally wouldn't have an issue with it, if the price is fair. Make sure you have all the records, and look through them thoroughly. Have fun!
