Old November 15th, 2008, 10:46   #1
Herm TDI
Herm TDI's Avatar
Default What do you do on a rainy Saturday morning
What do you do on a rainy Saturday afternoon ...you build an injector pop tester
I still have to mount the reservoir and inline filter. Other than that this unit is ready to go
Malone Tuning Service.
HermTDI@Yahoo.com
Herm TDI is offline   Reply With Quote
Old November 15th, 2008, 12:22   #2
nighthawk62
TDI(s): BANNED
Cool project! Will you be able to check the secondary spring and pop pressure?
BANNED
nighthawk62 is offline   Reply With Quote
Old November 15th, 2008, 12:24   #3
Herm TDI
Herm TDI's Avatar
Default pop pressure
Yes this will do the task nicely
HermTDI@Yahoo.com
Old November 15th, 2008, 12:24   #4
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
Nice work . What did the missus think about the washing machine smelling like diesel and hydraulic oil?
- Nick -
02 Jetta TDI 340k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old November 15th, 2008, 12:27   #5
Herm TDI
Herm TDI's Avatar
Default naugahide
Thats why I use a cover. Besides she was out spending $ which helps to keep her out of my hair.
You're gonna love what I'm using as the reservoir. Its a brake fluid reservoir really ideal because it compatiable with diesel fuel as well as solvants such a "Dieselkeen" & "Power Service"
HermTDI@Yahoo.com
Old November 15th, 2008, 15:20   #6
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: 116 mpg(e), 36 mpg gas, 100 mpg combined
Black iron and brass? Teflon tape? Are the materials up to the pressure needed to pop? Concerns about tape fines getting to the tips?
And can the jack develop pressure needed to pop a 220 bar (220 x 14.5 = 3190 psi) needle off its seat? If the piston is 4 inches in diameter the amount of area is about 12.5 square inches. To make 24000 pounds of force (12 tons) will require pressurizing each of those 12.5 square inches to just over 1900 lbs. The pressure at the black iron pipe on top will be the same 1900 lbs, far less than the 3200 needed for a 220 bar injector.
I believe the internal safety will prevent that jack from developing the 18 tons of force needed to obtain 3200 psi hydraulic pressure needed to pop the injector.
Svante Arrhenius 1896
Old November 15th, 2008, 16:01   #7
Ski in NC
Fuel Economy: 48-52 typical
Lug- I think (??) he removed the big piston, so the piston diameter that is developing pressure is that on the pump. Much better leverage there.
I could see that little ball valve crapping itself under 220 bar.
Cool idea. Definitely out of the box sort of contraption.
-Eric
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old November 15th, 2008, 17:28   #8
Herm TDI
Herm TDI's Avatar
Default interesting
People have been building these pop testers for years.
http://forums.vwvortex.com/zerothread?id=3630082
http://mercedesshop.com/shopforum/sh...d.php?t=224334
http://www.mercedesshop.com/shopforu...9&d=1116471009
I ran mine (injectors) this evening and it words just fine. This unit easily developes more than
adequate pressure and flow needed to perform the poptest.
What you do not see is a 200um filter cartrage (aircraft grade) at the enterance of the fuel line. Nothing is going to the injector but fluid. This is the component you do not see attached to the injector line inlet.
http://en-co.wika.de/upload/DS_AC0910_GB_4569.pdf
Just the same, thank you for your constructive advice.
HermTDI@Yahoo.com
Old November 15th, 2008, 18:17   #9
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
Here's mine. Built with hydraulic "rated" fittings. I use it on my IDI.
Little resovoir I added later. Actually more of a built in fill funnel.
Richard. ASE Certified Master Auto-Technician with L1 Advanced Engine Diagnostic Rating. ATRA Certified in Rebuilding, Diagnosing & Installing Transmissions.
LOOK AT MY YOUTUBE CHANNEL -->
https://www.youtube.com/user/CoolAirVw/
Now offering Malone Tunes!..............http://www.kansascitytdi.com/
CoolAirVw is offline   Reply With Quote
Old November 15th, 2008, 18:24   #10
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
Thats a dandy, where can I get one of those? One of the guys on another forum just found a "thimble" filter with a paper element, and placed it inside one of the fittings. Acutally pretty good.
Old November 15th, 2008, 20:00   #11
Herm TDI
Herm TDI's Avatar
Default filter
I got mine from a small local airport. There are owner pilots that will be more than willing to help you. You can get a used filter and if you let them know that you will not be using it on an aircraft will back flush it and clean it for you for less than $20.00
These filters are well made. Though they are intended to be consumeable (replaced after so many flight hours) for non-avation uses can be easily back-flushed and cleaned.
HermTDI@Yahoo.com
Page generated in 0.16705 seconds with 10 queries
[Output: 108.95 Kb. compressed to 91.68 Kb. by saving 17.27 Kb. (15.85%)]
