Appears you found yourself a pretty clean " one owner" car with a good maintenance schedule. Having the new engine mounts and a fresh alternator with new pulley is a good thing. It is not too hard to figure out if you have the metal alternator pulley or the plastic one. Just open the hood and take a look.
Ahh didnt know the update was simply the material, ill double check later on today.
The timing belt appears to have been changed, but remember every 7 years or 85-90k is the advised changed out interval.
I guess at this point, I would advise you to locate a TDI guru and have them assist you with changing all the fluids and all filters, which includes proper servicing of the automatic transmission and replacing the fuel filter. Inspect your brakes ( pads and rotors). Make certain you have a good set of wiper blades. Check all bulbs ( headlights, brake lights and turn signals). Make certain your sunroof drains are not clogged and re-seal the airbox plenum to prevent water intrusion into your passenger front compartment. Load test your battery and make certain you have a good battery. Also you may wish to remove those pieces of foam that are glued to the inside top of the front fenders. They are like little sponges that hold water and rust out your front fenders.
Yeah, my friend whos a tech is gonna help me do all the fluids at some point in the next week or so, hes not specifically a TDI guru since he focuses on whatever comes in (and he likes gas engines more) but hes a dam good mechanic so im pretty confident we wont screw anything up. Wipers were already replaced and bulbs are good, rotors and pads are new (our buying check list had most of this stuff on it
) Ill check the sunroof and battery today, i know the battery was replaced at 70424mi but ill still check that and the fenders too.
Then you should drive your car and enjoy the vehicle.
Do not loan your car to friends that could screw up and accidently put gas in the tank instead of the proper DIESEL fuel.
Down the road you will most likely face what we all face in terms of the
"BIG 3". Camshaft, Transmission, Balancer Shaft. There are lots of theories and advice regarding these three pricey repair concerns.
The trend tends to be having a TDI guru
(expert level TDI enthusiast / Technician ) do the following ---
Convert the car from automatic to manual transmission
replace the worn camshaft with a new and reputable camshaft kit
Install balancer shaft delete kit or VW gear driven balancer shaft unit
Install new timing belt kit ( everything is already apart so that it is a good time to just replace with new )
The upside is that you car appears to be a clean looking "one owner" car with good service history.
The downside is that we all face the camshaft, transmission and balancer shaft woes as some juncture in time. Some camshafts ( if proper oil was used) last a long time. Most automatic transmissions ( if properly serviced) also last a long time. That magic mileage number tends to be around 160,000-175,000 miles before things start failing and getting expensive.
The balancer shaft issue is the biggest concern for you right now and I am assuming it has not been changed. If it fails; you will have a big problem ( trashed motor ) and it will not be cheap to fix.
Once the big items have been updated / replaced; these tend to be really solid and well built cars. Please understand, you do not own a Camry or Accord, therefore do not expect the same type of ownership.
If you decided to update everything right now; plan on a budget of around
$5000-5500 to get everything done. These are not cheap cars to repair !
Once everything is done; you should have a pretty clean car.
If you are not a car person and if you do not want to invest the time and money into the updates; clean it up and market it to a TDI enthusiast and go buy yourself a new Camry with the 0% for 72 month financing deal.
Good luck and welcome to the TDI Club.
Oh dont worry no one is driving my new car, I usually never let anyone drive my vehicles unless theres an emergency or something serious.
But there is not a single chance im going to go get some toyota haha, I love messing about with cars. I usually try to do all my own work if i can and learn from the process, but i know VWs and european cars in general are a bit more touchy and require some decent experience before you mess with them, so while im still gonna do all the simple wear and tear stuff myself, ill go to my buddys TDI specialist for the big items.
So i guess my main priority right now is deciding if i want to do the new gear driven BS or just delete it. Im an electrical/computer engineer so i get how signals and systems work for electric signals, but i have no clue how second order harmonics affect engines/mechanical systems, but im guessing since VW took the time and money to design a whole specific unit to remove those vibrations, i should keep it in the system.
If i switch to the geared setup is there like a forged hex shaft for the pump i could get, or just one that wouldn't be as prone to failure like the stock setup?
As for the trans and camshaft, ill wait a little bit to take care of those, ill check the cam next time I change the oil or probably when i address the balance shaft and need to change the timing belt anyways. If the cam is good, should i replace it anyways as preventative maintenance, and if yes should i stick with the stock cam or go with an aftermarket one?
I don't think I'm gonna do a manual swap, as much as i would like a manual transmission that's just gonna cost more time and money than just getting a rebuilt automatic. My dad has a buddy who owns a transmission shop who did my blazers for cheap (since were good friends) so ill see if he does VWs. Plus Im terrible at driving stick haha, but you never know i could have a change of heart eventually and hate the automatic so much that i swap it. With the automatic though do they make higher performance clutch packs for these? I was thinking about a malone stage 1.5 or 2, tune on this after i drive it for a while and verify that everything is solid, but i dont want to put too much stress on the clutch packs and cause the transmission to fail prematurely.
Again thanks for the help, glad to be on this site.
