96Brian
Seems like the ongoing coolant loss I have been experiencing must be a head gasket leak creating vapor bubbles in cooling system and pushing coolant out overflow.
Question for group: if we have to tear down to head gasket, assuming block & head are ok, what else makes sense to replace/clean/check in the process?
Wagon has 127k miles, balance shaft delete, new egr cooler, egr cleaned 15k miles ago, lower turbo hose replaced recently and no performance problems or concerns (other than coolant loss). Camshaft at 90k with timing belt.
I hope to get another 100k out of this over the next 5 - 7 years, and I'm ok with spending a bit more on this project if there's other things that would make sense to change in the process.
thanks for your input
Brian
Oly, WA
Brian
Oly, WA
