Stealth TDI
Pre-Forum Veteran Member
Hi,
I've read a few dyno tests with TDI owners. Some guys make the runs in 4th gear. Others say to use 3rd because it pulls harder. Since most cars have a 1.000 4th gear ratio, I thought the idea was to use 4th gear in order to give that 1:1 ratio between the engine and the wheels. Then factor in the 17% loss with the transmission.
But many TDI owners are using third to get the higher torque readings. Since 3rd gear is obviously a lower gear ratio than 4th, isn't that multiplying the torque that's applied to the wheels? Are 3rd-gear torque numbers actually inaccurate? Someone please explain...
