PD Rig
Has anyone installed an aftermarket fuel filter head on their 2015 golf?
Yep! It's a modified factory bracket so it bolts right back in place.Nice. Looks like a drop in replacement. Definitely want to get my hands on one of those. Thanks for the picture.
Did you get the filter from Andrew as well or was it sourced elsewhere?Yep! It's a modified factory bracket so it bolts right back in place.
A pureflow kit similar to the MK6 likely won't work here as there is very limited space. This is why I asked Andrew to look into this filter upgrade!
The supplier (& maker) Andrew (2micron) lives in Ontario (but not Toronto). The best way to contact him is by email here: tdi2micron@yahoo.caHello,
I am located in the Toronto area in Canada. Is there a supplier or information on how to get one of these installed?
They technically would have to prove the upgrade is what caused any fault. But, that may require a ton of legal legwork.Im sure VW would probably use this as an excuse to void the warranty. Id love to have a 2 Micron system tho.
Not sure if they have gotten better since the MK6, but I believe those were 10 micron. The 1 micron is a no-brainer with a cheaper price and 5x the service life!Ok, what is the Micron rating on a 15’ OEM fuel filter ?
Dave
