Bravo.dieseldorf said:not as well as B2.
Let me rephrase (damn, I,m sounding like a lawyer).dieseldorf said:not as well as B2.
Quit drinking it!dieseldorf said:There's lots of BD in ME.
There's two of them, actually, and both have a horrible abbreviation:n1das said:I forget the name (and abbreviation) of the apparatus used to test diesel fuels for lubricity.
There are others out there who have similar thoughts. Thanks for your insight.LNXGUY said:I run 4 ounces of synthetic 2-stroke premix to every tank(BelRay H1R) If it helps lube a 2-stroke engine turning at 11K, mixed at 40:1, I have a feeling it helps my injection pump..
I would also love to put this up against BioD, I have a feeling the results would be very surprising...
__. If it's ashless (and I'd be amazed if you can find any non-ashless 2-smoke oil anywhere) it wouldn't make much difference. Diesel fuel is oil. 2-stroke oil is oil. If the 2-stoke component burns cleanly and leaves no ash, then it's no different from any other component in the fuel.blaz said:(snip) I doubt if anybody knows what 2-cycle oil does to the emission control stuff but it probably isn't too good. Bruce
I dunno how anyone can drive a diesel and honestly say a 2-stroke stinks.. Thats pretty ironic if you ask me. 4-8 ounces of premix into a 16 gallon tank is not going to do a thing to your emission control devices, the last thing I am worried about is toasting my cat because I have put a few ounces of premix in the tank. The biggest reason people hate 2-strokes is the sound (atleast when it comes to the recreation portion of things) Most modern 2-strokes have a powervalve, and when that valve opens up and the combustion camber becomes a little bigger and the engine starts to breath better, watch out!! 2-strokes are dead easy to maintain easy to fix, even if there is complete engine failure (a re-ring, hone and you are back in business.. No bent valves, no messed up cams, no this, no that) Personally, if I ever do pick up another bike (just sold my YZ), it will definitely be of the 2-stroke nature. And how can anyone complain about the power? I waste 450 4-strokes with my lowly 250 2-stroke.blaz said:You guys are focusing upon the possible benefits to the engine. What about the environment? There are reasons why people are being encouraged (or forced in some places) to replace their two-cycle engines with four cycle. 2-cycle stinks for one.
Bruce
My 2005 Passat doesn't stink !!!!LNXGUY said:I dunno how anyone can drive a diesel and honestly say a 2-stroke stinks.. Thats pretty ironic if you ask me.
LNXGUY said:I dunno how anyone can drive a diesel and honestly say a 2-stroke stinks.. Thats pretty ironic if you ask me. 4-8 ounces of premix into a 16 gallon tank is not going to do a thing to your emission control devices, the last thing I am worried about is toasting my cat because I have put a few ounces of premix in the tank. The biggest reason people hate 2-strokes is the sound (atleast when it comes to the recreation portion of things) Most modern 2-strokes have a powervalve, and when that valve opens up and the combustion camber becomes a little bigger and the engine starts to breath better, watch out!! 2-strokes are dead easy to maintain easy to fix, even if there is complete engine failure (a re-ring, hone and you are back in business.. No bent valves, no messed up cams, no this, no that) Personally, if I ever do pick up another bike (just sold my YZ), it will definitely be of the 2-stroke nature. And how can anyone complain about the power? I waste 450 4-strokes with my lowly 250 2-stroke.
Wally World sells it....Super Tech TC-W 3..."high quality ashless 2 cycle engine oil..."mrGutWrench said:__. If it's ashless (and I'd be amazed if you can find any non-ashless 2-smoke oil anywhere) it wouldn't make much difference. Diesel fuel is oil. 2-stroke oil is oil. If the 2-stoke component burns cleanly and leaves no ash, then it's no different from any other component in the fuel.
__. That being said, I'd agree with most of the other posters that 2-stroke oil is likely to give minimal improvement compared to other, more specialized additives. And, please, nobody pipe up with the old Marvel Mystery Oil bit.
They are working on it. Modern 2 strokes are cleaner and more effecient than they were 5 years ago. One of the biggest issues emissions wise was the 2 strokes would push some unburnt fuel out the exhaust. But this issue has been solved with..... Direct Injection!Joe_Meehan said:if I ever do pick up another bike .. it will definitely be of the 2-stroke nature.
Not likely unless you get it used. 2-stroke engines of all kinds are being regulated out of existence.
__. Thanks, Hank. This is good info - but let me ask to be sure that I understand you correctly. You're saying that Bombardier wants a "low-ash" oil and not an "ashless" oil? Having disposed of my last two-smokes recently (a pair of Maico rotary-valve road racers), I can understand about the need to lubricate the rotary valves - mine would get razor sharp after being run a few hours!hank miller said:Actually you can find plenty of low-ash 2-stroke oil if you know where to look. Bombardier engines have all required low-ash oil. The ash is really metal (zinc is my guess, but I'm not sure) and required to lubricate the rotary valve in their rotex engines. When used in their engines, it is the right thing, but it must never be used in anything else. (snip)
Why not every tank? I mean, does it clean out the tank/injectors, or is it a lube? If lube, I'd think you should use it all the time, no?cage said:Funny I just found this thread. I put lawnboy 2 cycle ashless in today. I do it a few times a year.
