Resetting tire pressure warning
Jetta_Pilot
West Hill, Ont.
Resetting tire pressure warning ( SOLVED Sept.20)
SOLVED Sept.20th:D
Had my car at the dealer getting the Phase 2 done recently. On the work-order it also states all tires set to 35Lbs.
Ever since that time I cannot get rid of the warning icon.
Tried pushing the reset button in the glove box, in the Multi function display, all to no avail.
This is not really a true tire pressure reading since it only works from the ABS brake sensors which can detect a change in tire circumference due to low air in the tires.
Eliminate a setting using a VCDS?
Anyone have a solution?
tadawson
Lewisville, TX
2013 Passat TDI SEL, 2015 Passat TDI SEL
Read your manual? To reset the system to a new pressure, iirc, you press *and hold* the button until you hear a chime . . . . specifics *are* in the manual . . .
oilhammer
outside St Louis, MO
Sometimes the NMS freaks out and the ABS module will not shut of the TPMS light until the car gets driven some. I have no idea why.
I would check the ABS controller for any DTCs, and I *think* there is a Basic Setting in there somewhere that forces the TPMS into relearn mode. Which should be the same thing pressing and holding the button does, but it does not always work.
Jetta_Pilot
West Hill, Ont.
I had checked the manual, but maybe missed the hold until it chimes. Will give that a shot.
Thx
I'll also check the ABS module for DTC's
Thx
tadawson
Lewisville, TX
Likely the press and hold will do it . . . The increased/changed pressure definitely will cause the system to alarm, as will tire wear over time, and I have never had a recal fail to correct those changes on either of ours.
Jetta_Pilot
West Hill, Ont.
Held the da*n button in the glove compartment until my finger turned blue with just power on and with engine running, didn't work.
Raining now so I'll try on a better day to see with the VCDS.
tadawson
Lewisville, TX
And you are certain that you got the "SET" button, right (I think I recall two, and my wife getting the wrong one once . . .). And no sound or change in the light? If so, it probably is time to check for codes . . . . (FWIW, I do this ignition on, not runing on mine . . . the button, not necessarily codes).
The dealer probably didn't see the light, since it takes a bit of time for the system to sense the change, but go back and gripe is anothernoption, since they fixed that which was not broken for you, apparently until it was . . .
TheGrove
S Central PA (Breezewood)
2012 Passat SEL Premium Opera Red - Dieselgate Fix, KermaTDI Tune, 2004 Passat GLS Northern Green-RIP
Been there done this - it won't work. The power needs to be on but the ENGINE OFF.
740GLE
NH
I had to be slowly moving while holding the button, but I also had my right index finger on my nose and saying "beep beep beep", not sure if it was needed, but it finally worked.
There is a trunk release "lock" button in the glove box, its a kinda valet feature. Make sure your not pushing that.
VCDS will be able to shed more light into it if all else fails.
Jetta_Pilot
West Hill, Ont.
Drove slowly for about 500' all the while holding the "correct" button. Got out of the car and hopped around the car once clockwise on one leg whistling Dixie.:rolleyes: Then repeated above!
So far nothing has worked.
Now waiting for my netbook to fully charge so I can scan the car.
740GLE
NH
well shoot, I got nothing, maybe whistling Dixie backwards?
Wiring for that button should go to the ABS module/controller, at least that's how button was wired on the mk5 platform, maybe a peak see of the loom by the ABS controller (located by the firewall) see if the DPF regens have done any damage to the loom.
Jetta_Pilot
West Hill, Ont.
Posting some scans done, one a year ago and two this year in August.
I cannot see any way to change things.
In one controller I get to chose between 2 axles, front and rear, light or heavy load and the default setting for the tire pressure is 5.5 bar. Maybe this needs setting to a much much lower number, I just see that 5.5 is 79.7708 PSI. Maybe set this to 2.0 bar which is 29PSI
Am I guessing right???:rolleyes:
My 3 scans:
June 13-2017
Address 03: ABS Brakes (J104)
1 Fault Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 24539 km
Time Indication: 0
Date: 2017.03.16
Time: 09:55:19
Freeze Frame:
Count: 2
Count: 14
Count: 4096
Count: 16401
Count: 43520
Count: 768
Count: 0
Count: 0
Address 65 Tire Pressure (J502)
2 Faults Found:
01521 - Sensor for Tire Pressure
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 255
Mileage: 19381 km
Time Indication: 0
Date: 2016.11.02
Time: 15:08:11
01325 - Control Module for Tire Pressure Monitoring (J502)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 19381 km
Time Indication: 0
Date: 2016.11.02
Time: 15:08:11
August 12-2018 This is after Phase 2 install
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 14
Mileage: 47377 km
Time Indication: 0
Date: 2018.08.10
Time: 03:24:59
Freeze Frame:
Count: 3
Count: 14
Count: 4096
Count: 16401
Count: 51712
Count: 65280
Count: 255
Count: 0
Address 65: Tire Pressure (J502)
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 255
Mileage: 34099 km
Time Indication: 0
Date: 2017.08.17
Time: 12:21:21
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 34099 km
Time Indication: 0
Date: 2017.08.17
Time: 12:21:21
August 29 -2018 This is after Phase 2 and Stage II install
3 Faults Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 57
Mileage: 47484 km
Time Indication: 0
Date: 2018.08.15
Time: 06:52:48
Freeze Frame:
Count: 0
Count: 14
Count: 4096
Count: 8194
Count: 45312
Count: 1024
Count: 248
Count: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 57
Mileage: 47484 km
Time Indication: 0
Date: 2018.08.15
Time: 06:52:58
Freeze Frame:
Count: 2
Count: 14
Count: 4096
Count: 16390
Count: 45056
Count: 1024
Count: 248
Count: 0
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 69
Mileage: 47377 km
Time Indication: 0
Date: 2018.08.11
Time: 03:24:59
Freeze Frame:
Count: 3
Count: 14
Count: 4096
Count: 16401
Count: 51712
Count: 65280
Count: 255
Count: 0
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 255
Mileage: 47394 km
Time Indication: 0
Date: 2018.08.13
Time: 00:39:38
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 47394 km
Time Indication: 0
Date: 2018.08.13
Time: 00:39:38
740GLE
NH
Go into the ABS module and see if they changed the coding to direct (IE the system is looking for sensors). I think there is long coding help that you can check.
Also in the module once in "indirect mode" you should be able to force it to start it's calibration.
dig around the mk5 folders, a few people converted their direct to indirect and provided the coding you needed to look for.
jjblbi
lbi, nj
2014 Passat SEL TDI
Try taking all your tire pressures up to 45psi, hold reset then go to your desired pressures and hit reset again. I think all pressures must be equal on the final setting.
tadawson
Lewisville, TX
The indirect system in the Passat cannot read pressures, so that is not relevant. It looks for changes in wheel speed due to deflation, and trips on that. Thus, you can calibrate it any any pressure you choose. Were this a direct system with wheel sensors, *then* you might have a point, but still dubious . . .
Jetta_Pilot
West Hill, Ont.
I'll give that a try tomorrow, have tried everything else.
Thx
740GLE
NH
agreed, it places trust in the owner to verify the pressure is set correctly and then does some math on each tire rotation and flags if that rotation math goes askew, either one tire or all of the tires.
You could set the TPMS with completely flat tires and it'd chime indicating the system was set.
Jetta_Pilot
West Hill, Ont.
Well I've tried all suggestions and none have removed the "Low pressure"icon from the instrument panel.
I'm just about ready to remove the clear plastic and black paint over the icon !
Jetta_Pilot
West Hill, Ont.
I've been sitting and thinking, I wonder if I need to get into the ABS system settings. Maybe it is in there that this problem comes from.
I've set and reset in the 65 and 04 modules to no avail. I do make notes of my changes!
tadawson
Lewisville, TX
Of course, having a dealer (or other shop) troubleshoot and fix the issue is always an option . . . . and a far better idea than jerry rigging things . . . . As others have noted, you see codes for wheel sensors that don't exist in this car, and, iirc, the problem began after a fix . . . Sounds like a coding error, and so eone elses problem to me at this point . . . . Was coding on the ABS controller ever verified?
Jetta_Pilot
West Hill, Ont.
Well a dealer may be an option, but after the Pase 2 and having re-installed my Stage 2 kind of makes me want to avoid the dealer.
tadawson
Lewisville, TX
And again, did you ever verify coding? With all the flashing, it's not impossible that something went sideways, and that was, (again iirc) about when this started, right?
740GLE
NH
also you can just turn off TPMS all together, nobody needs those nannies anyways.
tadawson
Lewisville, TX
Not sure how much difference there would be, but my wife's 2015 US SEL has this for the coding in the ABS controller:
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BS HW: 1K0 907 379 BS
Component: ESP MK60EC1 H46 0166
Revision: 00H46001
Coding: C54BC0F5492800FAA30B03EB92210042A1100012
Shop #: WSC 09003 957 00200
VCID: 04296A97875EB761CD-8050
Jetta_Pilot
West Hill, Ont.
I'd turned off all tire sensors, where ever I found them including the one that sets up in the MFD, made no difference at all.
Jetta_Pilot
West Hill, Ont.
Revision: 00H46001
I'll have to compare this to my scan readout and see if they are the same or not.
Edit: The exact same info in my scan.
But I also have this:
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 57
Mileage: 47484 km
Time Indication: 0
Date: 2018.08.15
Time: 06:52:48
Freeze Frame:
Count: 0
Count: 14
Count: 4096
Count: 8194
Count: 45312
Count: 1024
Count: 248
Count: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 57
Mileage: 47484 km
Time Indication: 0
Date: 2018.08.15
Time: 06:52:58
Freeze Frame:
Count: 2
Count: 14
Count: 4096
Count: 16390
Count: 45056
Count: 1024
Count: 248
Count: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 69
Mileage: 47377 km
Time Indication: 0
Date: 2018.08.11
Time: 03:24:59
Freeze Frame:
Count: 3
Count: 14
Count: 4096
Count: 16401
Count: 51712
Count: 65280
Count: 255
Count: 0
I've put in 40lbs of air pushed the button and then reduced it to 35lb exactly for each tire. Pushed the tire button in the glove compartment again, even heard a ding.
Makes no difference, the tire icon stays on. When I start the car it flashes and shortly after it stays on solid.
tadawson
Lewisville, TX
And again, I point out that this system *CANNOT* sense the actual pressure! It just plain does not work that way! All it sees is changes in RPM of a given wheel versus the others at a given speed, which corresponds to the change in diameter with pressure change. Period!
I think if you understood the system better, you might well have better luck with this . . . Not sure exactly what the "control module", but there is no such device by name or the "J502" in my car, again pointing to a potential coding error, perhaps in another place than the ABS controller. Not sure what your scan is from, but it does not look like VCDS, so hard to compare.
*Or* the Canadian system is different, and somehow got US coding . . . You really need to compare *everything* to an identical car to verify, or find someone who can.
06bluebeetletdi
Middlesex, NC
'14 Passat TDI SEL and '13 Beetle TDI
This is the key statement, there is something wrong in the system, whether it is a failed wheel speed sensor or something else, the light will not clear until you fix it. If it were just a simple push the button and reset the pressure, it would not flash on initial start, it would come on, go out for a second, then come right back on.
