6x6man
- Joined
- Jun 4, 2004
- Location
- East Troy, WI, USA
- TDI
- 2001 Jetta, 1999.5 Jetta, 2001 Golf, 2003 Jetta Wagon, and too many others I've lost count
Not sure if that shaft will work. I've got two in my garage for projects that I have planned and I looked at them. Both are the same, the shaft is smooth at the end where as yours has a flat on it and grooves in it. Do you have the cap/plug that the shaft goes into? When you look at the bottom of the transmission, it has the VW cast into it. I would be sure to use the cap/plug that was with that shaft.
