Old January 16th, 2018, 09:53   #6811
Yblocker
TDI(s): 1997 Passat
I think my Car Part.com inquiry for a used intercooler has attrcated the attention of a seller. I don't know how, but he sent me a PM on the forum.
He wanted $550 and when I said no thanks, he dropped to $360 shipped which still seems pretty high.
What do you guys think?
K03/04 hybrid turbo, RC II, Stage II Cam, Titan 502's, DC Stage I, TT LCA bushings
Yblocker is offline   Reply With Quote
Old January 16th, 2018, 12:51   #6812
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
What is the issue with the existing IC?
Proudly installing things where they're not supposed to go since 1996!
Windex is online now   Reply With Quote
Old January 16th, 2018, 13:05   #6813
Yblocker
TDI(s): 1997 Passat
It holds boost, but it's leaking oil from someplace above the lower hose connection- likely at a seam. It's not a profuse leak; it leaves a drop on the ground every other day if the car is driven consistently.
So I've been looking from time to time for a replacement. ToddA1 re-sealed his, but it sounded like it was difficult to re-crimp the tanks back on.
But $360 is more than I'm willing to pay.
Old January 16th, 2018, 16:42   #6814
TDIL3dad
Originally Posted by lisab4 View Post
Hi Todd,
Thanks for the link. The listing says you should get a link to a PDF with images and installation guide with your order. Maybe on a piece of paper, or in an e-mail?
Hi Todd;
Please do post on how this fits and works out.
I wonder if these are retrofitted used OEM controls, or newly manufactured controls. If newly manufactured, are they Far East cheap aftermarket parts, or better quality?
Will definitely consider as the Climate controls on both of my B4s are near death or completely dead.
TDIL3dad is offline   Reply With Quote
Old January 16th, 2018, 18:39   #6815
ToddA1
Fuel Economy: Dismal
You never heard me say that. Worst part was being sure everything was clean for the Ultra Gray. A flat drift and a mallet was used to recrimp/fold over the tabs.
I havenít looked for the paperwork to see if there was a link.
LL showed what was involved. Iíve seen others do the same and I donít really want to be bothered.
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is offline   Reply With Quote
Old January 16th, 2018, 20:31   #6816
Yblocker
TDI(s): 1997 Passat
Originally Posted by ToddA1 View Post
You never heard me say that. Worst part was being sure everything was clean for the Ultra Gray. A flat drift and a mallet was used to recrimp/fold over the tabs. -Todd
Sorry Todd- guess I heard it from someone else. I may yet do this for no other reason that there is no guarantee that a different used one will be any better.
Old January 18th, 2018, 09:08   #6817
Abacus
That helpful B4 guy
Abacus's Avatar
Fuel Economy: And the miles just keep ticking away
For $550 it should come with an attached engine.
Even $360 is pretty insane unless it's new in box.
'97 B4: 453,000 miles Malone 3, K03/04 Hybrid Turbo, PP520's, Stage 2 cam, SBC3, ARP studs, Westach EGT/Boost, Koni Reds/Yellows, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR, Evo plate,
'96 B4V: 356,000 miles Malone 2+, PP520's, 6 speed, 02J short shifter, E-Codes, G60 brakes, Evo plate, DMF, stainless exhaust, heated leathers, cold weather package
BUG*PWR 2013 Award Winner
Abacus is online now   Reply With Quote
Old January 18th, 2018, 13:35   #6818
ketchupshirt88
Fuel Economy: 40-42 with a lead foot.
You never heard me say that. -Todd
I was the one that said that I found crimping them to be a pain in the rear.
probably my lack of patience... but I decided to switch to a small aluminum FMIC rather than try to reseal another factory side mount with plastic ends.
I picked up my last used one from a boneyard for $40... for the $360 he is asking, you can go to a metal shop that builds them and have a new sidemount made from all aluminum.
2003 Jetta TDI - Boring daily driver for now...
1996 Passat TDI - "Red Death" RETIRED but still owned. Had a Malone stg 1 tune, 11mm pump, R520, GT15/17 hybrid and more
1997 Passat TDI wagon - Im not really sure why i bought this... anyone want a running donor car??? body is rough.
ketchupshirt88 is offline   Reply With Quote
Old January 18th, 2018, 13:46   #6819
Yblocker
TDI(s): 1997 Passat
Yeah, $360 aint gonna happen. It's not a huge leak really. I may address it when the timing belt comes due this Spring.
Old January 18th, 2018, 16:15   #6820
ToddA1
Thinking about it, I think I paid $20 for one from a local JY. That was the only A3/B4 TDI that Iíve ever seen in a JY, and that had to be 2 summers ago.
With some cardboard, Iím sure you could cut templates to make the tanks and have a shop weld them to your core.
Personally, Iíd just reseal it. You have nothing to lose.
-Todd
'97 B4: Stock
Rabbit build
Old January 18th, 2018, 17:46   #6821
Steve Addy
TDI(s): 97 Mk3
-Todd
Wouldn't doubt it, but the Mk3 are plentiful whereas the B4 not so much. There were never all that many B4 tdi's in the US and now 20 years later I would bet less than 50% of the original imports remain.
It's too bad they didn't share the same cooler, there were a bunch of Mk3 tdi's in 98 and early 99. Info I've seen says only 2% of the Mk3 cars in 1997 were TDI. Any way you slice it though there were more Mk3 than B4.
I'm with Todd, just try and reseal it and if that fails find a welding shop that will replicate the end caps in aluminum.
Steve
You didn't poison the coffee, did you? Not anymore than I usually do.
Old Yesterday, 19:29   #6822
ToddA1
Fixed a fuel leak on the B4. First time I’ve driven it in a few weeks, and I noticed a large stain in the street, as I pulled up to the house. Opened the hood and fuel was leaking pretty badly. Left another 2x4 stain, in less than a minute.
Tracked it down to a split return hose at the IP. Replaced all the jumpers and soaked the engine and street down in degreaser. Hosed off the engine, but left the street alone. Rain is coming in, and I figure I’d let it soak.
-Todd
'97 B4: Stock
Rabbit build
Old Yesterday, 20:03   #6823
john.jackson9213
TDI(s): 1996 B4V
Just got the B4V back from 4 days in the shop.
1) Front motor mount steel was cracked, rubber was fine. Welded the steel. Seems fine now.
2) Replaced the oil pan gasket again. Last one was only a year old. This time sealant used on both sides of the entire gasket.
3) Replaced all 4 CV joints at the same time. Only one side really needed replacement and could have milked the other side a while longer. BUT, now both sides are done and should be good. New parts are TRW.
Shop had a heck of time finding the correct CV joints. In part because of my big brake conversion (VR6 brakes), but mostly because B4 parts are just simply getting hard to find in the marketplace.
JJ
1996 B4V, Hella E-Codes, GLX leather, EuroTuning.cz 02A 6 speed conversion w/.71 5th and .588 6th gear, A4 shift linkage by Matt-98AHU. 11 mm pump by Oldpoopie. Now, GTC1549VZ turbo by Whitbread. TDtuning, 24 lbs. boost, 162 hp, 285 lb/ft tq. Smoke Free (9/18/15). Koni Yellows and Big Brake 5 lug conversion.
john.jackson9213 is offline   Reply With Quote
Old Today, 00:13   #6824
Lenard
TDI(s): 97 B4 TDI
Fuel Economy: No idea. Broken clusters are no fun.
Originally Posted by Steve Addy View Post
I was just reviewing my spare parts collection yesterday and it does not include a working starter. It does include three inop starters though, not that those do much good.
I would prefer to keep a working spare in the group since I know my wagon starter is not OE. Now to decide whether to have one rebuilt locally or look at getting a Bosch reman unit.
Steve
Steve, I ended up picking up a Bosch reman. Luckily I'm very good friends with the manager of a local Napa, so I get parts at cost.
Since I last posted on this thread, I've had to make many wire repairs. Mostly the injection pump wiring. My injection pump is clearly not the one that originally came with the car. Looks brand new. I have a feeling someone replaced the pump thinking it would solve underfueling issues, when it was actually a completely broken quantity adjustor wire. Also some wires were bypassed At the plug, so I redid them with solder and heat shrink instead of the butt connectors that were there. I was a little upset at the hacked up pump wiring, but then I remembered I have an 11mm alh pump with the wiring cut back about a foot....just need to find a vnt17 before I can justify the swap.
Let's see what else have I done. Completely refreshed front end, short of struts. New snow tires and alignment obviously. After all that was squared away, my nice tight steering revealed a little bit of play in the rack. Not doing anything about it until it's scary.
Finally got around to timing the pump and tweaking IQ after I cleaned injector nozzles and put them on mk4 bodies. Had to ghetto rig a "flow tester" (which was a little rubber boot that came off the backside of a bmw e36 head light. One end fits in nozzle, the other is just big enough for your standard blow gun) to make sure all five holes were spraying. Have some .216 nozzles on the original injector bodies waiting for me to have time to either a) fix my pop tester, or b) get them pop tested and balanced by JasonTDR. I've also got a vnt15 swap on standby to get my foot in the door of vnt and replace my dying turbo. Gotta wait til funds are available for the tune.
Ooooh and I've mounted a double din stereo in the cubby hole under the ashtray. The original stereo slot now has a 3d printed gauge pod waiting to be mounted. I think I may finally fit that tomorrow and take some pictures.
1998 Jetta AHU 5 speed SOLD @240Kish
2005 Jetta BEW auto. SOLD @208495K exactly.
1983 Jetta Diesel Coupe 4 speed. SOLD at ? Miles
1997 B4 Passat 1Z 5 speed. Mileage? Current diesel toy
Lenard is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Page generated in 0.29179 seconds with 11 queries
[Output: 127.10 Kb. compressed to 106.86 Kb. by saving 20.23 Kb. (15.92%)]
