Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old November 9th, 2018, 07:32   #1
tdi_514
Default 2014 jetta tdi steel(winter) wheel size?
Hello all
New owner of a 2014 TDI and excited to drive it. I live in Canada where winter tires are required by law. For winter tires/wheels I used to go 1 size down and I searched this forum with conflicting info. Some say if I go down to 195/65/15 it won't clear the brakes and some say it's ok.
Can anybody confirm this?
tdi_514 is offline   Reply With Quote
Old November 9th, 2018, 18:21   #2
GD
GD's Avatar
You should be fine with 195 65 15
TDI'ers Do it Better!
2007 Benz ML320 CDI too many toys to list
2011 Jetta TDI (CJAA) Highline DSG Reflex Silver 165,000 kms
2004 Jetta TDI PD (BEW) Platinum Metallic Grey 340,000 kms SOLD
2000 Jetta TDI ALH Black 398,000 kms, TT LCA Bushings, TB changed at Windex GTG SOLD
GD is offline   Reply With Quote
Old November 9th, 2018, 18:56   #3
tdi_514
yeah? I find it weird that none of the tire websites list that size. My other vehicles always showed the OEM size and one size lower for rims.
Old November 10th, 2018, 07:05   #4
195/65-15 is correct.
Old November 10th, 2018, 08:36   #5
GD
GD's Avatar
Take a look at your spare tire, what size is it?
Old November 10th, 2018, 10:58   #6
tdi_514
Yeah I just came across that it's a size smaller. Cheers!
Old November 13th, 2018, 20:02   #7
Jolly
TDI(s): MKIV Golf 5
If you calculate the diameter and circumference of the stock tire/wheel and find a corresponding winter tire of equal diameter and circumference, you should be good.
My wife’s jetta stock size was 225/45R17 (if I remember correctly), which is just under 25” diameter. There was a lot of snow tire varieties available in the 16” option. So I ended up getting 195/60R16 which was just a bit over 25” diameter.
And I really like the thinner 195mm winter tire option compared to the wider stock tire size for summer tires.
Long lost VW Diesels from the past;
1980 Rabbit; 115,000 miles - So long old friend....
1981 Rabbit; 184,000 miles - parted out
2000 Jetta; 225,000 miles - sold for a profit
1999.5 Jetta; 289,000 miles - soon to be parted out
Jolly is offline   Reply With Quote
2014 TDI Stock/OEM Tire and Wheel Size snednchic VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 9 December 18th, 2014 10:22
2014 Passat TDI with Jetta 16 Steel Rims? ssstw1 VW Passat Family (NMS and B7) TDIs (2012+) 5 February 14th, 2014 11:11
Wheel size question - can I reuse old steel rims? -2003-2012 i_winter TDI 101 4 September 20th, 2012 12:26
need advice on size of best size of wheel/tyre for winter cog TDI 101 3 December 30th, 2010 12:35
winter tires and wheel size ExBimwad TDI 101 9 December 14th, 2010 00:47
Page generated in 0.15337 seconds with 13 queries
[Output: 80.25 Kb. compressed to 69.71 Kb. by saving 10.54 Kb. (13.13%)]
