AC compressor clutch not working.
12volts at connector.
Bad compressor?
Will vag-com help troubleshoot the AC on 2010 Jetta?
Anyone know of an easy way to hook up battery voltage to the compressor to check clutch or how an inductive amp meter could be hooked up with out dismantling the front end of the car?
Bad compressor?
