Hi lambo,
I thought you said in your other thread, where I explained how these turbos fit (welded manifold vs RyanP tubular manifold), that you only had £350.
You realise this GTB conversion is easily going to cost £2000 (in parts alone), what with the turbo, manifold, balanced injectors, remap/tune, uprated SMIC, stronger clutch, hoses, etc.
If you've found some more money then the cheapest way to do it is TIG weld a 1.6 TD manifold onto a GTB1756VK (which also has to be converted to from electronic to vacuum actuator, so watch out for that on eBay,etc, as will add cost), and you will need a flange too, which RyanP sells.
Other parts to get the most out of your set-up:
- 11mm injection pump or frankenstein hybrid pump (£500-700)
- PD Lift pump
- Uprated engine mounts (otherwise you'll get too much wheel spin)
- Uprated brakes (pads and/or full brake conversion, or you won't be able to stop properly)
- Uprated suspension/bushes & strut braces + ARBs for handling
- Boost / EGT gauges (to monitor these levels so they don't get too high and cause damage)
- 3" exhaust
