Seen a P13D4 code a couple of times since the spring (cylinder 3 glow plug). Winter is coming so I'm finally trying to eliminate the problem, which might mean replacing the glow plug.
Sure enough after taking the engine cover off, there's a bunch of debris around the glow plug sockets, probably stashed there by some critter :/
I'd like to test the connection and the plug itself, but the newer harness doesn't look the same as tutorials I can find online. Anyone know about these new plugs and how to safely remove them? I don't want to just start yanking on them unless that's the right thing to do...
