Pcar993
I have a MyCruiseAgent egt probe thru my egr. What temp are you all seeing for vnt17/22 with 3" turbo back exhaust?
Wow.. and I thought I hit high numbers. I can get to 1700 rather easily and have hit 1850 or so on occasion - Cobalt EGT gauge with MCA EGR probe.pegged the 2000*F (cobalt autometer) gauge easily when i was running my 17/22 - usually on very spirited runs at full throttle from bottom of 4th to top of 5th. My last dyno with that setup was 198hp/390tq. Probe was installed through the EGR port and was inches away from the turbine. Got hot VERY fast! temps always dropped quickly once took my foot off the accelerator.
Is that to the wheels? What dyno machine?I dyno'd at 180HP/285TQ. How did are your TQ numbers ~ 105 ft lbs higher?
Yes, to the wheels on a DynoJetIs that to the wheels? What dyno machine?
1200?? Seriously?? Lame... Why do you even have PP520's and RC3? You might as well put a 2x4 under the "gas" pedal.The turbo may be ok up to 1650F, your stock pistons however... not so much. Having seen way too many engines damaged from excessive fueling, I don't run above 1200.
ive got a Kerma 3"
with r520's and a 10mm pump i get about 1400. thats about it though... around here its gereally pretty flat and i dont tow so 20 seconds of that will put me in jail....
i dont have the fuely-est tune nor is my IQ set real rich (ie not a low #)
also using a mycruiseagent
See Fix_Until_Broken's post near the top. He's seen high EGTs. He's also broke a piston. Anything above 1400 and you are rolling the dice.1200?? Seriously?? Lame... Why do you even have PP520's and RC3? You might as well put a 2x4 under the "gas" pedal.
1400F for 2-3 minutes multiple times and 1200F for an hour.
+2. it wasn't stabs of 1600*F, it was the long hill climbs for extended periods of time, and towing large loads on some of those runs that did the pistons in. Kevinski, you've got room for more everything.Originally Posted by Fix_Until_Broke said:1400F for 2-3 minutes multiple times and 1200F for an hour.
good questionThose who are seeing 1600+, how is the smoke level with the tune? Can the EGT run that high with a light haze OR no smoke at all? I'm thinking some tunes/ adjustments people run are too agressive. The difference between a haze and a bunch of smoke is not much hp, but tons of EGT!
Fix Until Broke said:......It was all I could do to maintain 70 MPH. On the flats I was running ~15 psi boost steady state. I ran it up to 20-21 psi on the hills but coolant temps started to get over 220F so I didn't push it any harder. I ran the whole 100 miles with the windows cracked, full heat and the fan on 4 to keep the coolant temps below 220F. I turned the fan off once because my feet were about to start on fire and the scangauge temps went up 2 degrees every 5 seconds so I turned the fan back on at 228F and rolled the windows down a little more. It was ~30F ambient temp outside and I removed my lower and middle grille blocks so airflow shouldn't have been an issue. I'll need to look into possible other cooling problems as I've never had this kind of issue with keeping things cool, even in the summer.
I went 50+ miles with the boost never below 15 psi, coolant temps never below 215F, EGT's never below 1100F. IATs were 80-100F, engine RPM was 2000-2100.
Highest EGT's were ~1400F but typically 1200F-1300F
There was a 15-20 MPH head wind which does not help anything. This is the only time I've wished I didn't have the 205/70/15's instead of the 195/65/15's - that additional 6% bump in RPM's would have helped quite a bit from a power standpoint.
I slowed down to 60 MPH on the 2 lane roads and the coolant temps were a little lower (running ~215F typically, but still climbed over 220 on hills). I tried running slower but below 55-57 MPH (1700 RPM) I got on the wrong side of the torque curve and couldn't accelerate at all. Downshifting to 4th wasn't an option that I was willing to do unless I absolutely had to, so 58-60 MPH it was.
I'm pretty sure PDs can get away with higher EGTs. Still I'd be scared to see 2000deg.Wow.. and I thought I hit high numbers. I can get to 1700 rather easily and have hit 1850 or so on occasion - Cobalt EGT gauge with MCA EGR probe.
I have a MCA block off with Newsouth gauge/probe. Pre head/block work i would see 1700deg temps, but i also cracked a piston clean in half. Now with the motor and head all done and R520s i don't even see 1500deg.
I think it needs to be on the path of flow inorder to get true reading. Anything less would change temp. Significantly.yeah im running the newsouth probe as well. I did notice that the MCA probe is a bit longer, but and im assuming the NewSouth probe is a tad less than "ideal" as it may be a 1/2 inch out of the exhaust stream. Anyone have any thoughts on this? the newsouth probe is only about 3/4 inch shorter than the MCA probe, and in the MCA instructions it is suggested that you leave about 1/3inch poking out the top. does the remainging 5/12 inch-ish difference effect the reading greatly?
Thoughts?
