Old August 3rd, 2018, 16:43   #1
Uberhare
Uberhare's Avatar
TDI(s): Too many.
Fuel Economy: Depends on what I'm towing!
Default W8/Auto to TDI/6spd Discussion
Looking into the fall months, I'll be converting one of my W8 Wagons (auto) over to TDI 6 speed manual. I've started to collect the parts already, I believe I have everything now except a propshaft. I've come across a driveshaft spacer targeted at Allroad M/T swaps here:
http://audis4parts.com/audi-a6-tip-t...eshaft-spacer/
In theory it should be the same distance I need to take up in my swap. Any thoughts on this?
2004 Passat W8 Variant, awaiting BHW swap
Retired: 2005 Passat BHW Variant w/01E 6 gang
Uberhare is offline   Reply With Quote
Old August 3rd, 2018, 16:43   #2
Uberhare
Uberhare's Avatar
TDI(s): Too many.
<place holder for later>
Old August 3rd, 2018, 16:45   #3
bbob203
TDI(s): b5.5v
Fuel Economy: 38-42
Most interesting. I wonder if it will work.. I was planning on getting a propshaft from frans but may go this route.
bbob203 is offline   Reply With Quote
Old August 4th, 2018, 09:37   #4
yahmon
Cool, looking to do the same this winter, mine already manual and looking to swap the frr code trans with a ftf trans. Not sure if there are differences, think it would be straight swap. What code or ratio are you planning?
yahmon is offline   Reply With Quote
Old August 4th, 2018, 16:27   #5
Uberhare
Uberhare's Avatar
TDI(s): Too many.
The gearbox is a GLX from a 2003 2.5 TDI. The ratios are as follows:
1st is 3.75
2nd is 2.05
3rd 1.32
4rd 1.07
5th is 0.71
6th is 0.56
Final: 3.89 (to match W8 Auto rear diff)
Old August 4th, 2018, 16:39   #6
Uberhare
Uberhare's Avatar
TDI(s): Too many.
FYI: W8 Manual is 4.11 rear diff
Old August 4th, 2018, 17:52   #7
bbob203
TDI(s): b5.5v
Fuel Economy: 38-42
Do you think the 3.89 final drive is better than the 4.11?
Old August 4th, 2018, 18:58   #8
PickleRick
PickleRick's Avatar
4:11 is Considered a better towing range ratio by many USA based diesel/gaser truck/suv manufactures but it means more rpm/less mpg at freeway speeds
The goal for the bhw in the passat is sub 3000 rpms at 80mph.
Nobody exists on purpose. Nobody belongs anywhere. We’re all going to die. Come watch TV.
PickleRick is offline   Reply With Quote
Old August 5th, 2018, 03:59   #9
bbob203
TDI(s): b5.5v
Fuel Economy: 38-42
1st is 3.75
2nd is 2.05
3rd 1.32
4rd 1.07
5th is 0.71
6th is 0.56
What code is it?
Old August 5th, 2018, 09:17   #10
Uberhare
Uberhare's Avatar
TDI(s): Too many.
Code is GLX. I only considered the 3.89 since I have 4 W8's here with that ratio! 4.11 is probably better for towing, but that's probably less than 1% of my driving. Lots more 4.11 boxes available than 3.89.
Old August 5th, 2018, 09:35   #11
yahmon
I think there were some 5 speed 4 motion's with the 3.89 rear diff
Old August 5th, 2018, 10:28   #12
yahmon
manual 5 speed 4wd GGH has 35/9 gears, actually all of these do,
35/9
Model data: EFC,EYH,DYE,GGK,GGN,GGH all used in passats, not sure engine model
Should be able to use on of those rear diffs to match to glx right? or am i blowing smoke here?
Old August 5th, 2018, 15:16   #13
QuickTD
Yes, I have one in my A4, code DGW. Got it from Frans a few years ago. At the time he said it was scarce, though there may be more available now.
QuickTD is offline   Reply With Quote
Old August 5th, 2018, 15:26   #14
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
Don't get hung up on the propshaft too much - I know a couple places in Mississauga who can fabricate / lengthen / shorten as needed - do it all the time on the heavy truck side of things.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old August 5th, 2018, 16:11   #15
yahmon
the ftf will turn about 1918 rpm at 62 and the glx about 1815 rpm, either way they are getting down there, will the BHW get better on mileage the lower you go?
FS: 2003 VW Passat W8 Wagon - 6spd nitec Private TDI Items for Sale/Wanted 18 September 17th, 2016 11:25
FS: 2004 Passat W8 Wagon 6spd (NOT A TDI) psst1997 TDI Cars for Sale/Wanted 9 October 2nd, 2014 12:07
Found a 6spd man w8 4motion passat for sale! alhdude General VW Discussion 2 March 23rd, 2014 14:51
swap out 4spd auto for 6spd auto in 2k2 nb TDICROW TDI 101 1 February 6th, 2009 21:40
2006 Jetta Tdi Pkg1 DSG 6spd Auto chazavw TDI Cars for Sale/Wanted 8 October 25th, 2008 08:51
Page generated in 0.19125 seconds with 11 queries
[Output: 123.96 Kb. compressed to 103.02 Kb. by saving 20.94 Kb. (16.89%)]
