jackbombay
No, if you cut both wires and connected the ends from the ECU with a resistor you'd get a "permanent reading" based on the resistance of the resistor, but that's not what's being discussed here.
From what I recall in college the cutting of one wire is all that is required to open up the parrallel circuit . As long as the open part of the circuit is open to ground there should be no (R1)(R2) / (R1 + R2 ) = Rt . It should be just R1 + R2 = Rt ., R2 being the varring resistance with fuel temp of the fuel temp resistor . I went and dug out my electronics books from school .jackbombay said:No, you asked about cutting one wire and placing inserting a resistor there, mike asked about replacing the sensor with a resistor.
But we aren't talking about PD's, at least I'm not.DPM said:As previously discussed, replacing the sensor with a fixed value is EXACTLY what the cheapo PD tuning boxes do, and no, it doesn't set a CEL.
It's about six weeks later, Rotarykid. Has your opinion changed since the initial glowing report?rotarykid said:After a week I can say the above mod ;
Increased fuel economy by 20 to 30 % . I exceeded 200 miles before the fuel gage started to move off of full , normally the gage starts to move in the 130 to 150 mile range .
This mod will increase smoke on a car that already smokes.Doc_Oc said:Too bad it didn't work, I need less smoke
Well, all the previous posts were stating the contrary.jackbombay said:This mod will increase smoke on a car that already smokes.
I haven't had a chance to try this mod yet, but from my readings here it should not increase the smoke.jackbombay said:This mod will increase smoke on a car that already smokes.
Did you get a CEL with the resistor left in the pin 7? I had exactly the same thing happening on mine. But with the resistor in pos 7 I would get a cel and gp light flashing. I didn't have vagcom though to see what the code is.WolfTDI said:I just tried this mod and the car would not run with both resistors in. I put one resistor in the pin 7 Yellow/Blue and one in the pin 2 Grey/green. I removed the resistor from Grey/green and it fired right up. I haven't had a chance to drive it yet, but thought the results were interesting.
