Cha2ga
DLC1019 installed! Wooohooo!
letting my car sit in the same spot while away on business for 2 weeks
anyone want to see a video of the startup when I get back home?
I thought I was taking a video, but lack of caffeine in the morning I went out to start the car resulted in me looking silly (no video recorded, sorry!).Yes.. Yes please.
Thanks for the advice guys gonna rethink my approach.Im going to keep my opinion to myself, last time it got me banned.
...I can't help myself. X2, please do not shove xenons into halogen housings.. you'll blind oncoming drivers at night.
+1 Wankel7. I learned my lesson, and that was on a Mk4!
The newer model VW headlights have a more pronounced 'shield' in front of the tip of the Halogen bulb, and this will reflect the super-bright HID light even more. Highs or Lows, it doesn't matter...they have a ****ty pattern and you will see less at night, or in weather. 2200 lumens FTW!
Just my 2cents. Good luck jboystdi.
-M.
If you are installing HID bulbs into reflector housings....please do not do this.
http://enthusia.st/hid-headlights-why-you-shouldnt-use-them/
Please.
I agree totally.
I believe, eventually, all the people who are Installing HID bulbs in halogen housings are going to cause new laws / regulations that will adversely effect those of us who did it properly.
Yes, this is so annoying. And I'm pretty sure it's illegal too....aka you can be fined for it.
Personally I'd go for a whole new headlight assembly with the Xenon and leveling system. If I could justify the cost.
What bushings did you have in your BFI mounts? Was the vibration too much?Replaced my drivers front abs sensor
Removed my drivers and passenger side BFI engine mounts, went back to stock....... Good lord the car is so much more pleasant to drive. I left the stiffer dogbone in.
Reinstalled the H&R sport spacers. Had to modify the front 8mm ones to work with the new hubcentric rings i also purchased. Apparently the 8mm ones had been revised so my old ones were no good. Its handy having a lathe at home!
These were the older yellow stage1 unitsWhat bushings did you have in your BFI mounts? Was the vibration too much?
I've always wondered if it was worth upgrading mine. Already replaced the Dog Bone with one from ECS Tuning with the 70A durometer polyurethane bushing. But I haven't touched the other stock engine or transmission mounts.
That sticker looks good! I was thinking about oneNot much, just added a sticker to the golf lol
Thanks!Wankel7, lookin' good buddy!
Nice work Wankel7,Finally finished my hid retrofit
To reset the service interval on an 09, you need to go into the MFD (the heads up display on your dash) and go to settings, there should be an option of service interval down the list, select reset service interval from your options.I changed my oil in my 09 Jetta tdi. At 52, first time I've ever changed my own oil.. I've completed all kinds of other jobs on other cars I've owned - it's about time I did an oil change! Now I need to know how to reset my computer so it doesn't tell me I need to "Service Now!" every time I turn on my car... help please? I'm guessing I can use the Autozone loaner OBDII to do this.
Unfortunately, I wasn't able to find instructions posted here in tdiclub for changing my oil. I found great info at this outside link: http://www.myturbodiesel.com/wiki/e...vw-jetta-golf-sportwagen-tdi-and-audi-a3-tdi/
Though everyone here helped me choose my oil (Liqui Moly with 507 specs) and my oil filter (Mann), and also helped to point me in the right direction when I replaced my tires last fall.
Next job is probably brakes - front left is making some noise, and the pre-purchase inspection let me know that this car (lived first 6 years of its life in Minnesota) has some problems with the left front brake caliper. Fun! I like learning curves.
