Borg-Warner Turbo info from factory
loudspl
Osakis, Minnesota
02 ASV w/ 02J
The 2000+ deg. Ti & ceramic material is interesting
I've been to the plant here in Asheville, NC a few times....very nice facility
Whitbread
Vendor , w/Business number
Johannesburg, MI
Several
One of the efr6758's with a vnt17vb with an external gate would be a nasty street combo :). I'm always trying to talk friends into using one of the EFR turbo's on a project, they're always all for it until they see the price haha.
ryanp
Barnsley, South Yorkshire, UK
Arosa CR - 550hp - 9.7 @ 150mph 1/4 Mile, Citigo 4x4 CR TDi - 340hp, Caddy 2.0 CR 4x4 TDI - 300+hp, Golf Mk2 Van 1.9 TDI - was 290hp, Mk5 Ibiza 2.0 FR TDi - 270hp, BMW 135d - 360hp, BMW 330d - 335hp, BMW 335d - 380hp + a few more ........
My fabricator is not impressed with them at all, one car has killed 3 and another is on its second. That did not make the power so now he uses GTX Garrett turbo's!
They were all replaced FOC by BW so its nothing to do with the car!
On paper they are the nuts!
Whitbread
Johannesburg, MI
Several
Very interesting, that sucks. You'd think a company as large as BW would get things right..
loudspl
Osakis, Minnesota
02 ASV w/ 02J
If Gus's build is any indication, one would think it's possible to go even larger on the LP and still remain street-able. If those ARPs will hold :eek:
FWIW looks like they have one comparison done in the UK with GTX series vs. BW EFR and the BW was a bit better:
http://www.full-race.com/store/turbos/borgwarner-airwerks/borgwarner-s200sx-7670-turbo.html
Of course, this could be biased info so who knows. Some of BW's larger turbines have ceramic BB CHRA, watercooling, and single/twin scroll options.
Not sure what Garrett is offering in terms of thermal capability with the GTX series. They improved on the flow and PR with GTX but what about handling higher EGTs?
NoJoke
Not sure where the LP in my application is most efficient I'm hoping 3.8k rpm but its not too late to change:D if I'm not happy.
diffas
Finland
B5q A4 Avant 2.5TDi+, B7q A4 Avant 3.0TDi
I'm attending to go 6258 in some time on my 2.5tdi with smaller 0.65a/r turbine.
Atleast if trusting bw match bot, it should work just fine.
counting specs;
http://tinyurl.com/69ncf24
dieseleux
Théoricien -TDIClub Contributor
Pas assez loin pour vider ma tank!
Jetta TDI 02
counting specs;
http://tinyurl.com/69ncf24http://tinyurl.com/69ncf24
VE are too high for TDI.
Muffler System Backpressure and intercooler drop pressure rise at square of rpm.
Better power without too much smoke with A/F at 16:1
Good calcul sheet!
Dieseleux
diffas
Finland
Well I used that site own tips to make calculations. I wanted to result almost smokefree thats why with higher a/f ratio.
