SAABNEWBIE
I bought this car from out of state and I need to pass smog to register it in California. Former owner had his mechnanic install a Rocket Chip 1 tune.
Is there a way to flash this car to stock form, pass the smog and then reflash the current stage 1 tune? Right now, using VCDS the EGR Readiness is showing "Failed or Incomplete" even after driving 1500+ miles and several drive cycles after installing a new battery. Further digging with VCDS shows neither the MAF actual nor the EGR actual values do not change, regardless of load. Car drives the same with MAF disconnected. It seems to point to an EGR delete mod option from my haphazard research.
What can I do next?
What can I do next?
