TdiRabbi
Hello all, I have a 2001 Golf that I just purchased about a week ago. I got it cheap knowing it needed some work, one of which is getting the AC and power windows working again. To clarify, my blower motor works but the AC clutch is not engaging, and none of my doors will actuate their windows.
Is there something that controls both of these? I have 90psi of refrigerant without the compressor running so I know it's enough to atleast cycle the compressor. Also the driver's switch panel is pretty banged up, do all the doors get their power from the driver's switches?I know my 05 dodge ram was this way. I only found one wire with 5volts at the driver's switch panel harness. Also power mirrors aren't working either, if that helps any.
Any help would be appreciated!
