Gothmolly
My steering wheel is not centered on the gauges, it looks like its slightly angles in towards the center of the cabin. Anyone else have a setup like this?
TDIRyan said:get the alignment checked.
That is exactly the issue. These morons don't know how to do an alignment. The left tie rod NEVER gets adjusted. You do the toe setting from the right tie rod.madrean said:whitedog, if both tie rods are adjusted an equal amount in the same direction, wouldn't this result in a cocked steering wheel?
gothmolly, i'm only saying this because i believe this happened to me in the past (pre alignment, steering wheel ok, post alignment, steering off).
(i'm by no means an aligment or crooked steering wheel expert)
yes, this is what i have read recently (that you should only adjust the right side). i have a feeling that the first time the alignment was done on my car (at sears) they were doing trial and error with BOTH sides and i ended up with a crooked steering wheel.jasonTDI said:That is exactly the issue. These morons don't know how to do an alignment. The left tie rod NEVER gets adjusted. You do the toe setting from the right tie rod.
But this has nothing to do with gothmollys situation.madrean said:whitedog, if both tie rods are adjusted an equal amount in the same direction, wouldn't this result in a cocked steering wheel?
