160 mbar: Houston, we have a clog
Sure,
I do not have the latest update. As far as I know, I had the DSG software updated, (for recall, and it now shows the gear number in drive and sport) but no engine controller update I am aware of.
Our cars are very similar -- mileage, updates. Had the mechatronic replaced under warranty years ago and with that update I too got the gear indicator on the MFD. I've had the car to the dealer for various issues, but don't believe the 23o6 has been done to my car. Do you know which cars it applies to? At first I thought it was only those with SCR, but some with LNT-only models said they'd gotten it too.
(does the engine controller identification info on VCDS indicate the flash updates?)
I'd love to know the answer to this.
Anyway, finally made the time to collect data on this issue. Note that I've had a continuous P0401 error code/CEL for probably 6 months/10K miles -- cracked DPF a near certainty. Very sooty tailpipe:
Values/readings taken on a cold engine. My P0401 (when it wasn't a constant failure condition) would always trigger right at start-up or after a few minutes of driving. Idle lines are values when first reading the group, ON is after pressing the ON/OFF/Next button once, OFF is after a second press. Last DPF regen was 130km ago/132 minutes of runtime. VCDS version 15.7.1.
Group 67 1-4 values (function test adaptation):
idle: 828 rpm, 100%, 99.4%, 12.6%
ON: 1403 rpm, ON, 520 mg/str, 39.5%
OFF: 1403 rpm, OFF, 555 mg/str, 99.4%
Group 68 1-4:
idle: 828 rpm, 100%, 99.4%, 7.1%
ON: 1403 rpm, Lid close, 92 mbar, 19.7%
OFF: 1403 rpm, Lid open, 23 mbar, 99.4%
Group 78 1-4:
idle: 8 mbar, 25.5, 0 mbar, 42 C
ON: 164 mbar, 76.5, 0 mbar, 54 C
OFF: 162 mbar, 76.5, 0 mbar, 60 C
Group 78 1-4 at a slightly hotter temp (more minutes of idle in garage):
idle: 8 mbar, 25.5, 0 mbar, 72 C
ON: 156 mbar, 76.5, 0 mbar, 84 C
OFF 156 mbar, 81.6, 0 mbar, 90 C
then back to idle:
idle: 8 mbar, 20.4, 0 mbar, 84 C
Group 3 1-4 (at idle):
805 rpm, 38.0% (EGR spec), 37.1% (EGR actual), -11.8% (EGR duty cycle)
If the numbers/values look like I dorked something up or didn't take them properly, let me know and I can recheck.
