billiebbyy
- Joined
- Dec 18, 2018
- Location
- Anniston, AL
- TDI
- ‘06 VW Jetta TDI - BRM Engine 212k Miles - 2nd Owner - DIYer
So I’m about to do my first DSG fluid/filter change. The car is almost fifteen years old (2006) so most of the rubber has or on the brink of disintegrating... When I change the fluid, I’m also going to change the gasket but I saw a hole on the pan that has two rubber seals as well that you can see the mechatronics unit through (from the diagram I saw). I’m just curious if there is anything I need to know before getting into this job. It’s definitely due for a change so any info or DIYs you can link would be greatly appreciated. I’m just a little hesitant being that I’ve never done this before. I could get in there and it all be self explanatory, but I’d love to hear your opinions beforehand in case it isn’t. ��
