Go Back   TDIClub Forums > VW TDI Discussion Areas > General VW Discussion
General VW Discussion This is a place for General VW topics (the company, not your vehicle). General topics about a specific vehicle should be posted in the General TDI Dicussion Forum sections for that vehicle platform. A4, A3 & B4, B5, etc.
Old February 3rd, 2008, 13:16   #1
oilhammer's Avatar
Fuel Economy: fantastic
Default Volkswagen part numbering system
OK, a quick lesson in how VAG (Volkswagen, A.G.) part numbers work for those who have asked. I am by no means the top expert on this, but I will try to share what I know.
The VAG system uses two seperate systems, one for most all the normal parts, and another for many fasteners, hardware, o-rings, bulbs, etc. I will be discussing the former system that most people would want to be familiar with in dealings with the cars.
The number consists of 9 digits, 3 'sets' of 3, and sometimes a letter (or a couple letters) suffix at the end. Looks something like this: 010 321 371 B. There is a method to the madness, and here is how it works!
The first set denotes what that part fits. This set will typically be one of three types: platform, engine, or transmission. Keep in mind, many early cars (going WAY back here) will use the same set to denote all 3 types. But with all the later stuff, it will be broken down. Now, what do I mean by these 3 types? 'Platform' refers to a specific body or chassis type. 'Engine' is a specific engine that may be used in several platforms. 'Transmission' once again may be used in several platforms. This 3 digit set will tell us what the part fits, and every platform, engine, and transmission will have its own unique code. For instance, if you have a 1998 Jetta, the most common platform codes for that car will be 1H0 or 1HM. If your 1998 Jetta is a TDI and uses the AHU engine, its engine parts will mostly have a 028 code, if those parts are specific to the AHU engine. Its manual transmission will carry a code of 02A.
So if we see a part number that is 1HM xxx xxx x we can assume that whatever the part is, it fits an A3 platform Golf, Jetta, or Cabrio, and it may fit other platforms if they employ the same part.
That first set can be more specific within the platform. For instance, the Jetta is based on the Golf. They share 90% of their parts. But something Jetta specific that is NOT the same as the Golf may have a different 3rd digit. Same goes for different body types within a platform (2 dr versus 4 dr, for instance).
The second set of numbers is the main group. This actually narrows down what the part actually does. The main groups are divided into 9 categories:
1: engine and clutch
2: fuel tank, pipes, exhaust system, heater
3: transmission
4: front axle, differential, and steering
5: rear axle
6: wheels and brakes
7: hand and foot controls, safety covers
8: body and sheetmetal
9: electrical components
The first digit of the second set will denote which main group category the part is from. So, if our part number is xxx 1xx xxx x we know it is an engine or clutch part. This center set will break down even further to get you closer to what the part does. For instance, a '98' denotes a kit of some kind. '21' denotes water cooling parts. So, a part number that has a 198 in its center set is a kit for an engine, like a gasket kit for example. A part number with 121 in its center set is most likely a coolant hose, pipe, a water pump, radiator, etc.
The last set is the part control number, just an actual sequence number and is usually not too important in actually identifying what the part is and what it fits. It just narrows it down the rest of the way to get exact. One useful hint here: if the part in question has a left and a right, like tail lamp lenses, for instance, the RIGHT side will end in an even digit, and the LEFT side will end in an odd digit.
The last little bit is the suffix. These are not always present. Usually this denotes a newer or updated version, but not always. Important note here is that if a VAG part number ends with an X, that denotes that it is a remanufactured part, and will need to be returned for a core.
Now, all the first set codes can be tough to remember, BUT thank goodness Volkswagen has always been very good about putting the part numbers on just about every part in the entire car! This can help you quickly and easily get a replacement. Keep in mind, however, that there are always numerous supercessions as well as omissions, so these are not always 100% reliable.
Ok, so let's say you had some freak rock come flying up and break your brand new Jetta's left outer tail lamp... the part number is 1K5 945 095 J.
1K5 is the A5 Jetta platform set
945 we learned the 9 is electrical, and 45 is the tail lighting code
095 tells is which specific part, and that odd number 5 insures us it is the left side.
J just means the current revision for the US spec Jetta tail lamps
So, when you are tinkering with your car, and you see those numbers on those parts, try it out and see if you can understand how that part got its number! Also, this is very useful when ordering parts, and insuring you get the correct parts.
Hope you all find this helpful, and please ask if you have any questions!
www.cardocautomotive.com
Old February 3rd, 2008, 14:55   #2
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
In the "old" days, the part numbers usually refered to the original model in which a specific part was first used...
I'm not sure if they're still doing that, but I suppose that if they again started using some parts that originally were used on an old air-cooled Beetle, they would use the same basic part number - possibly with a new suffix...
I may be showing my age...
Yuri.
ymz is offline   Reply With Quote
Old February 3rd, 2008, 14:58   #3
oilhammer's Avatar
Yuri.
Yep that is usually true. The part about the numbering system, not your age....
Old February 3rd, 2008, 18:04   #4
Growler
Got Soot Vendor
Growler's Avatar
Awesome post Brian!
~Aaron~
Schmutz 2015 GSW S DSG
Schnurren 2001 Golf 2 door.
Old February 3rd, 2008, 18:19   #5
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
Thanks!
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old February 3rd, 2008, 19:43   #6
Nocky
Nocky's Avatar
Fuel Economy: 50-43
I wish vw would have a web site like Kawasaki They have a parts list for every bike. http://www.kawasaki.com/DefaultFrame...HOWVEHTABS%3d1
Nocky is offline   Reply With Quote
Old February 3rd, 2008, 22:20   #7
scurvy
Good Ol' Boy
scurvy's Avatar
TDI(s): 2006 Golf
Fuel Economy:
Thumbs up yet another awesome post
Thanks for this information, oilhammer. It actually starts to make sense how these part numbers are derived, and not just some random or squential system! Another AWESOME post from a top-notch guru that was fortunate enough to have taken the factory training.
Just to clarify your point about parts on both sides of the car with odd vs even ending numbers: if a part has an odd number, it is on the left side of the car - but left is taken as the driver's left as they sit in the driver's seat, correct?
If you post a question, post your solution!
mk4 front wheel bearing | scurvy winter front | VCDS in Chicago, IL USA
You are entitled to your opinions but not your own facts.
scurvy is offline   Reply With Quote
Old February 4th, 2008, 05:05   #8
oilhammer's Avatar
Left and Right are always as sitting in the driver's seat of the car, correct. For instance, in a Jetta the timing belt (if equipped) rides on the right side end of the engine.
Thanks everyone for your compliments!
Old July 23rd, 2008, 10:44   #9
Scott_DeWitt
Scott_DeWitt's Avatar
Default Another good write up
http://www.justfourrings.com/phpBB2/viewtopic.php?t=920
www.advancedautomotion.com
Scott_DeWitt is offline   Reply With Quote
Old August 16th, 2008, 20:41   #10
SCModerator
Deciphering parts numbers is one thing -- but where can I go to get the part number of something I need?
I see the online VW parts houses carry more than they list, and they generally need a VW part number to get you what you might need.
Is there an online resource or something akin to what the VW dealer uses?
Thanks.
SCModerator is offline   Reply With Quote
Old August 17th, 2008, 08:13   #11
Scott_DeWitt
Thanks.
Only for Euro Models whcih will cover most of your parts however USA specific items you will be SOL on.
http://www.vagcat.com
Old October 21st, 2009, 13:45   #12
Shay2n10
Does anyone have a schematic of the interior pieces? I need the cupholder schematic for the back seat in a wagon. I need the full schematic of those pieces.
Shay2n10 is offline   Reply With Quote
Old March 6th, 2011, 11:19   #13
P2B
P2B's Avatar
This is really useful to know if you've just bought a used set of variant crossbars that have seen a few Canadian winters, disassembled them for cleaning and lubrication - then realised there's a bunch of parts that look the same but are slightly different to accommodate the angle of the roof rails
Thanks oilhammer!
Jettas for 29 years, TDIs for 13.
2003 Silver Jetta TDI GLS 220K PP520 RC3 6-Speed ERF
2003 Silver Jetta TDI Wagon 180K PP520 RC2
2000 Canyon Red Jetta TDI GLS 300K
P2B is offline   Reply With Quote
Old January 5th, 2014, 09:49   #14
diesel4sure
Fuel Economy: 32+in town 40-42 highway
I have a 2005 Jetta TDI wagon. It was a two body style year. I am trying to find a drivers side front splash Guard (shield) for the wheel well. How can I find the VW
part number so that I can shop this part ?
Thanks,
Joe
diesel4sure is offline   Reply With Quote
Old January 5th, 2014, 11:56   #15
ymz
Originally Posted by hike823 View Post
I have a 2005 Jetta TDI wagon. It was a two body style year. I am trying to find a drivers side front splash Guard (shield) for the wheel well. How can I find the VW part number so that I can shop this part ?
Your car is a MkIV - same as the 1999.5 - 2004 Jetta / Golf... shouldn't have trouble finding parts...
Yuri
Pereat mundus, fiat musica!
Page generated in 0.17508 seconds with 12 queries
[Output: 131.38 Kb. compressed to 109.80 Kb. by saving 21.58 Kb. (16.42%)]
