willyraz
Car stopped running while driving on the highway. (POSTED LAST WEEK) Code P1248
Finally got my parts. So today I replaced the timing belt. Had 80K on the belt. All was fine, did not jump and timing seemed to be OK but replaced to confirm. Car still dos not start. YES Timing is on. Hooked up the jar. This pump does not seem to be taking the fuel. Is there anything else I can try before condemning the IP. Fuses are good and I have check engine light and glow plug lights on when I turn on the ignition. HELP!! not sure what direction go. What about the switch on the top of pump??
