Do some homework first -
At 212,000 miles I decided to replace the struts and springs on all 4 corners.
I really didn't care for the aftermarket options so I did some research and put drop out struts/springs/mounts from a wrecked 2014 GLI that had 6,000 miles on it. Not bad for $160.
For the back I used the same GLI shocks and went to the Tiguan springs to raise the rear up a bit. Upon taking everything apart in the rear, both OEM rear springs were broken.
Good luck with your decision.
