Old January 14th, 2018, 09:48   #1
bookem34
TDI(s): 2000 jetta
Fuel Economy: 38 to 42mpg.
Default shift solenoid A electcical
I'm getting a po730 code shift solenoid A electrical. I've checked the solenoids on the valve body and they are all good. need an idea where to look next.
bookem34 is offline   Reply With Quote
Old January 15th, 2018, 12:50   #2
jef@rosstech
Associate Ross-Tech Vendor
Are you sure about that DTC number? There is no "po730", and P0730 is a gear ratio fault code:
http://wiki.ross-tech.com/wiki/index...4/P0730/001840
Jef blah blah blah
www.Ross-Tech.com
What should you do first with VCDS? AUTOSCAN!
jef@rosstech is offline   Reply With Quote
Old January 24th, 2018, 06:05   #3
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
where are you getting that definition? P0730 is gear ratio error which basically means computer "sees" the transmission slipping.
Richard. ASE Certified Master Auto-Technician with L1 Advanced Engine Diagnostic Rating. ATRA Certified in Rebuilding, Diagnosing & Installing Transmissions.
LOOK AT MY YOUTUBE CHANNEL -->
https://www.youtube.com/user/CoolAirVw/
Now offering Malone Tunes!..............http://www.kansascitytdi.com/
CoolAirVw is offline   Reply With Quote
shift solenoid A bookem34 TDI 101 2 January 13th, 2018 11:28
Need help with: Shift Lock Solenoid Colexius TDI 101 1 August 16th, 2013 20:09
shift lock solenoid error 18169 thundershorts VW B5 Passat TDIs 4 April 25th, 2011 14:37
How to change 02 jetta shift solenoid jmooreTDI TDI 101 13 February 13th, 2011 20:40
"Shift Solenoid E" fault code TDI Dick VW MKIV-A4 TDIs (VE and PD) 6 August 29th, 2004 10:44
Page generated in 0.16051 seconds with 11 queries
[Output: 57.66 Kb. compressed to 52.31 Kb. by saving 5.35 Kb. (9.28%)]
