Old October 10th, 2016, 07:15   #1
dieselherb1
Default vagcom problem too many communication errors
I have a 2003 Jetta it was a gas 1.8 now alh . Starts and runs but can not check timing. I can read codes with vagcom with key on but when I start engine it goes to too many communication errors to continue. Timing and I are out of adjustment. Everything else in car works fine
Help please
dieselherb1 is offline   Reply With Quote
Old October 11th, 2016, 13:58   #2
jef@rosstech
Associate Ross-Tech Vendor
What version of VCDS are you using?
What does all of the writing on the interface say?
Jef blah blah blah
www.Ross-Tech.com
What should you do first with VCDS? AUTOSCAN!
jef@rosstech is offline   Reply With Quote
Old October 11th, 2016, 20:34   #3
dieselherb1
I'll check tomorrow. VCDS works on all the other cars I've worked on
Old October 12th, 2016, 08:53   #4
dieselherb1
Its a 11.11.5 version. I can read and auto scan codes with engine off, once started them too many comun. errors.
did a autoscan codes 17970 16612 17654 17762 00849 01064 00625 01330 01336 01299 01314 01177 00771
Old October 12th, 2016, 08:54   #5
dieselherb1
Is there anyway to buypass to set engine timing and IQ?
Old October 12th, 2016, 09:53   #6
jef@rosstech
11.11.5, way out of date. Lets first try a fresh install with the current version. Here is our web page to download the latest version:
http://www.ross-tech.com/vcds/download/current.php
Once you get the current version, let us know if it helps. If not, we'll see about getting a debug report from the current version of VCDS, that might yield some clues.
Jef blah blah blah
www.Ross-Tech.com
Old October 12th, 2016, 11:03   #7
JSWTDI09
JSWTDI09's Avatar
One other point: What computer and what operating system are you using? Is this the same computer you have used before with VCDS? I have heard of multiple communications problems with newer laptop and tablet computers with Windows 10 relating to the computers power management. Look into power management and look at the advanced settings and look for power settings related to USB. Computers trying to reduce power usage (save batteries) can cause VCDS communications issues if they try to cut USB power.
Have Fun!
Don
JSWTDI09 is offline   Reply With Quote
Old October 12th, 2016, 11:09   #8
Vince Waldon
Vince Waldon's Avatar
2X, important next step.
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is offline   Reply With Quote
Old October 12th, 2016, 18:03   #9
dieselherb1
The computer is an old Dell with XP. It works fine on all other cars, not this one. Swapped ECU no change.
Old October 12th, 2016, 19:31   #10
Vince Waldon
Yup, so something's going on specific to this car... a dump of the VCDS log will be very helpful in tracking this down, as posted above.
Old October 12th, 2016, 22:01   #11
tadawson
Running on batteries or ? I seem to recall someone having flaky comm running, iirc, power to the laptop from the car or some such . . . If not running fromthe laptop battery, it might be worth a try . . .
tadawson is offline   Reply With Quote
Old October 13th, 2016, 07:05   #12
dieselherb1
couldn't load new version. Windows says remote device or resource won'taccept the connection
Old October 13th, 2016, 07:32   #13
dieselherb1
tried another laptop with 11.11.5, same results can read codes till I start the car then t-m-c-errors
Old October 13th, 2016, 11:04   #14
Vince Waldon
Please post the debug logs you're getting with your *current* version of VCDS... the version that's giving you all the communication errors.
Otherwise everyone's just batting at smoke.
Old October 13th, 2016, 11:31   #15
tadawson
I'd still like you to answer my question regarding power source for the laptop . . .
- Tim
Too many communication errors (VagCom) TDI_Michael OBD Scanners 12 August 3rd, 2016 20:06
vagcom problem too many communication errors dieselherb1 OBD Scanners 0 July 31st, 2015 20:20
VCDS ABS communication to many errors Curious Chris OBD Scanners 2 February 9th, 2015 16:25
tons of "No Communication" errors - engine, trans, ABS, airbags, steering, cent conv. Ghastly VW MKV-A5 Golf/Jettas 7 January 21st, 2015 22:31
Too Many Communication Errors to Continue kopeck OBD Scanners 3 March 24th, 2005 11:12
Page generated in 0.17417 seconds with 11 queries
[Output: 122.71 Kb. compressed to 102.11 Kb. by saving 20.60 Kb. (16.79%)]
