Old March 11th, 2016, 11:21   #46
DanB36
Originally Posted by Rico567 View Post
Will it turn service reminders off in your '13?
Haven't had occasion to try yet--just got the '13 two weeks ago. It has a function that claims to do that; I'll see if I can find more information about it.
DanB36 is offline   Reply With Quote
Old September 7th, 2016, 06:36   #47
Srb88042
TDI(s): 06 jetta
Can this be used to shut off the engine light after removing the egr?
Srb88042 is offline   Reply With Quote
Old September 7th, 2016, 14:37   #48
tadawson
Nope, it's a scan tool, not an uploader . . . and even if it would upload, you would not have an image that would accomplish the task to upload . . .
tadawson is offline   Reply With Quote
Old September 8th, 2016, 10:18   #49
JohnTso
Fuel Economy: 51/47/42
If the VAG401 allows checking/verifying IP timing for the ALH engine, I would be very interest in picking one up.
JohnTso is offline   Reply With Quote
Old January 13th, 2018, 15:15   #50
Don't Panic
I guess I will start my first post on this forum by reviving an old thread.
I purchased a VAG401 mainly to run the fuel pumps for a filter change and I am having the same issue as others have mentioned in this thread (only primes for 1 second). From what I have read, this is due to a software issue with the latest version V8.4.1. Does anyone have an older software version that they could send me? Unfortunately Xtool was unable to help and I couldn't find anything on the net.
Thanks.
Don't Panic is offline   Reply With Quote
Old June 3rd, 2018, 22:52   #51
Spiked1Z
Fuel Economy: 36 city, 47 Highway
Probably just how it works I have one though havenít thought to use it to prime the system.
I just popped off the return line and used a mighty vac to get air out, then after a few cranks started right up.
Also helps if you fill the filter housing with diesel.
Spiked1Z is offline   Reply With Quote
Old October 30th, 2018, 15:04   #52
bananaman82
Fuel Economy: 48 mpg
Wake up little dead thread....Can this somehow read boost????
bananaman82 is offline   Reply With Quote
Old October 30th, 2018, 17:28   #53
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
It will read absolute boost which is what the ECU sees.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Vag 401 scanner by XTOOL 2015 GOLF TDI S OBD Scanners 21 December 21st, 2015 13:59
Tack reads low by 500 RPM, Temp gauge low dt racer VW MKIV-A4 TDIs (VE and PD) 0 April 6th, 2014 19:30
Coolant temp never reads above 76.5C in VCDS?? bhodgkiss TDI 101 8 June 6th, 2013 05:54
Temp Guage reads hot & blinks at key start (cold) teamspoad Other VW Group TD(I)s 2 July 9th, 2011 05:48
Temp sensor reads hot at startup ENG TDI 101 5 December 12th, 2009 09:50
Page generated in 0.13422 seconds with 11 queries
[Output: 84.75 Kb. compressed to 73.30 Kb. by saving 11.45 Kb. (13.51%)]
