zaathur
i been searching and haven't came up with anything on how to disable the factory alarm with vag-com any one know how to do this
do you have an aftermarket alarm? maybe something is loose, haven't heard this particular complaint much here on the forumif you can't disable it is there a way to disable the horn without unpluging it for some reason if just a person talking next to my car the alarm will go off or if a loud truck drives by it will go off
That's what I was thinking. Aftermarket unit. On the 2000/'01/'03 I've had, none of them had sensitive OEM alarms or could be set off w/o opening a door while locked.do you have an aftermarket alarm? maybe something is loose, haven't heard this particular complaint much here on the forum
There you go. Bad door switch. Do the indicator lights/interior lights not come on w/any door?this is what i noticed today when i open the doors the door open indicator does not light up but my interior lights come on when i open the doors and the chime turns on, my truck indicator seems to be working fine
Is there a way to disable that? Sometimes I unlock mine with the remote but don't get in right away and it locks itself back on meIf the car is locked and then unlocked w/remote and then that door is opened and closed the car will relock itself because it doesn't get a signal that the door was opened.
