slapshotjh
I did a B4VR6 to tdi swap this spring. Its been a disaster. So far I have had to replace the transmission in the donor car, replaced the head, and a whole slew of other odds and ends. Ultimatley, I cannot rely on this motor, its making a racket from somwhere in the vicinity of the oil pan.
I know this swap isn't generally recommended. I have a B4 with a lower end noise, the engine is a 1z. I also own an A3 with an engine that runs fairly well, but the car has rust issues and wouldn't sell for much.
I'd like to swap the good engine from the A3 into the B4. The A3 has limp mode, I believe its the wastegate, everything else has been replaced including the actuator. So I would like to swap the whole intake/turbo assembly over. I think I need to do that anyway as the downpipes are different, so I assume the exhaust flange coming off the turbo is different too.
1. Is the engine wiring harness different? I am wondering if I can plug the B4 ECU harness into the A3 engine harness, or if I need to swap engine harnesses as well. I am talking about the harness that is on the engine starting at that big round plug that you undo to pull the engine out.
2. I think the transmissions are the same, do I have to swap flanges or anything?
3. Is the gasket between the head and the exhaust manifold reuseable? Its only been on there for about 700 miles.
4. Anything else that I would need to swap from the B4 engine over to the A3 engine?
Thanks!
Thanks!
